Passenger Side Wire Mod -->Done! Got Pics
Old Oct 24, 2004 | 09:37 PM
NoFear95's Avatar
http://home.comcast.net/~j.burks/DSC01438.jpg
Dont see many LT1 guys doing it. Now to get rid of the air system to clean it up.
Old Oct 24, 2004 | 09:52 PM
joshp007's Avatar
Re: Passenger Side Wire Mod -->Done! Got Pics
I did the same thing but I also moved the red power supply box too so you see no wires at all. Let me know if you want pics. Your engine bay is very clean though!! I like it
Old Oct 24, 2004 | 09:57 PM
NoFear95's Avatar
I'll PM you my email addy for pics. Thanks man!
Ran out of time and motivation to do that. Been putting this off for some time now. One step at a time.
Old Oct 24, 2004 | 09:59 PM
Lower's Avatar
Looks nice!
Has that fenderwell been repainted?
Old Oct 24, 2004 | 10:03 PM
NoFear95's Avatar
Nope all stock........some day.
Old Oct 25, 2004 | 12:16 AM
n2oblkz
Guest
Posts: n/a
I have seen this mod with the LS1 cars on LS1tech.com but had never seen it done on an LT1. Did you guys splice the wires or did you drill the hole big enough to get the connectors through. I'm not big on cutting up the wirring harness so I may tray to cut the hole big enough for the connectors.
Joshp007
Where did you put the power supply box? This was one thing that I was wondering about, I don't think that the LS1 cars have that box, so I was wondering where to put it on mine. Also, do you have any pictures?
Old Oct 25, 2004 | 10:57 AM
NoFear95's Avatar
Cut a 1 1/2 hole. Its just big enough to get the head of the connectors through.
Old Oct 25, 2004 | 12:21 PM
CamaroCasanova's Avatar
I did mine about 2 years ago, both sides, fuel lines, all of it...What a PITA, the driver's side, I cut a hole about 2"+ in the wheel well, and ran it up underneath where you can't see it...However, all of the harness (like 80 wires) had to be extended. The passenger side does not need an extension.
I can put pics up if you want but you can kind of tell at my site www.camarocasanova.freeservers.com
or some
better pics:
www.camarocasanova.4t.com
It definately cleaned up an awful engine compartment!!
Old Oct 25, 2004 | 12:42 PM
ibanez6rg's Avatar
Too much work for my blood.
Old Oct 25, 2004 | 12:51 PM
AW/whiteZ-28's Avatar
I've been wanting to do this for awhile, where did you get the rubber grommet for it?
Looks great and now you have a place for the F-bod father to sign one day!
Old Oct 25, 2004 | 01:40 PM
NoFear95's Avatar
Just used the plastic wire loom and rapped those in a rubber hose. Couldnt find a grommet big enought for the life of me.
camarocasanova, your car is SICK! :-)
Old Oct 25, 2004 | 01:44 PM
NoFear95's Avatar
Camarocassanova, Where did you get the Power steering Fulid Res from? Custom?
Old Oct 27, 2004 | 04:06 AM
02transam 513's Avatar
Whats the link to instructions to do this
Old Oct 27, 2004 | 08:38 AM
NoFear95's Avatar
1.Remove the right front wheel and then the plastic inner fender.
2. Drill a 1-1/2 diameter hole in the steel fender well between the hood strut reinforcement and your PCM from the underside. It is easier if you find the place from the top side and drill a small hole as a pilot from on top.
3. Unplug all of the wires from the harness. Don't worry about how to re-plug them - there is only one way they will re-plug.
4. There is another wire that runs from the PCM harness down to a speed sensor (I think) that will need to be disconnected and re-connected.
5. Run the wires from the PCM side through your new hole. Run the other end of the harness through the existing space next to your battery down to the wheel area. Then re-plug your harness.
6. For safety sake, I neatly wrapped the wires and plugs with electrical tape to protect the harness and to keep the wires neatly together.
7. Now just put your plastic inner fender back in , and your tire, and you're back in business
Old Oct 27, 2004 | 04:09 PM
LT1 Bunny's Avatar
thats all you need to do??? ill have to check that out tonight!
