Passenger rear quarter panel rattle
Old Nov 14, 2003 | 07:19 PM
jchrisos's Avatar
Unhappy Passenger rear quarter panel rattle
Does anyone know how to tighten up the rear quarter panel on the passenger side of the car? The Borla exhaust is making the panel vibrate and not only is it annoying, it sounds embarassing!
Please help!
Jim
Old Nov 14, 2003 | 08:22 PM
2 SC Zs's Avatar
Post
Silly question on my part... Are you sure it's the quarter panel? I had a rattle in the same area awhile back. Wound up that somehow the wingnut holding the spare tire and jack had backed out a little and that was where MY rattle was coming from.
Hope it helps, if not good luck!
Old Nov 14, 2003 | 10:15 PM
jchrisos's Avatar
Not silly at all... I'd be the silly one if I didn't try that already
I currently took out the jack, spare tire, screw, etc. and it helped a lot. I am assuming it's that panel because from the outside, I can push in on the quarter panel and it moves quite a bit.
I appreciate the info though. Thanks!
Jim
Old Nov 17, 2003 | 01:23 AM
ROADRAGE's Avatar
The rear quarter panel cant "come loose" Its a piece of the unibody, it's welded to the floorpan. It could be your bumper or bumoercover, but I cant see how it could be your 1/4 panel
Old Nov 17, 2003 | 10:18 AM
jchrisos's Avatar
From my understanding, the quarter PANEL covers the bumper or any part of metal underneath it. Whatever you want to call it, it's the platic piece that has one of the red lights on it. It's not welded because it's plastic and I can push in on it.
Hope that clears any confusion for everyone. Any ideas how to get inside it or tighten it?
Thanks!
Jim
Old Nov 17, 2003 | 01:09 PM
ROADRAGE's Avatar
Thats the bumper cover. The q.p. is the entire metal piece that goes from the door to the taillights.
The bumpercover is held on by a bunch of small screws and thumbscrews. You can check most of them if you take out the panel inside the hatch that covers the taillights
Old Nov 17, 2003 | 05:23 PM
Alanrk's Avatar
I had a rattle like that once, turned out to be my radio antenna....
tightend it up, rattle went away.
Alan
Old Nov 17, 2003 | 07:08 PM
ronin013's Avatar
i have a rattle in the same area and i cant find it, had it ever since the day i put my hooker cat back on ive checked around and under the car several times, fixed some other rattles and vibrations caused from working on the car, but this one still illudes me...
Old Nov 18, 2003 | 09:24 PM
KillerTA's Avatar
Try putting some dynamat (sound deadener which is mainly used for car audio) on the back of the bumper cover.
That should do the trick because it'll add some weight and it'll help absorb some vibrations.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Richardan15
May 30, 2015 08:36 AM
blown94
May 3, 2015 12:48 AM
WildRidez
Feb 23, 2015 07:24 PM
redleader
Jan 22, 2015 12:05 PM
