Painting interior - Question about primer
Old Mar 11, 2006 | 02:21 AM
concubine_number_4's Avatar
Question Painting interior - Question about primer
Hey guys,
I've begun to redo my interior. I've gotten all the sanding done and am ready to apply primer. My problem is I'm using a fabricated center panel that was previously painted red and then grey over top, I've almost sanded off all of the grey but the red will not come off.
If I use a CLEAR primer on the red panel, and on the regular plastic sanded panels, will the silver paint im using be a different color on the panel that was red? I plan on using 4 coats of primer, 5 coats paint, and 4 clear coat.
this is the primer I'd like to use: http://www.duplicolor.com/products/adhesion.html followed by dupli silver and dupli clear coat.
Any help would be gladly appreciated, thanks for your time.
Old Mar 11, 2006 | 11:27 PM
meissen's Avatar
Re: Painting interior - Question about primer
Personally, while DupliColor does call it that, I wouldn't call it a primer. I'd use the adhesion promotor to get the tack, then duplicolor high-build primer ontop of that. sand it smooth, then paint.
Old Mar 12, 2006 | 06:42 PM
SFB767's Avatar
Four coats of primer, 5 of topcoat and 4 of clearcoat is overdoing it.
Sherwin-Williams makes a universal bonding primer in a quart that costs about $11. The part # is B51W20. One coat of this will promote enough adhesion to just about any topcoat you choose to apply over it.
2000silverz28
Sep 7, 2002 01:48 AM
TheV6Bird
Aug 27, 2002 10:38 PM
BadBowtie93Z28
Aug 9, 2002 07:52 AM
TheV6Bird
10
Aug 2, 2002 08:00 PM
TheV6Bird
11
Jul 28, 2002 05:25 PM
