painting brake calipers
just some questions.......is it hard to do?.......who has done this....and does it last ? thinking of doing mine......silver car.....will red be too loud?...i was thinking of black? i will be putting on ZR1 wheels in about a month, so they will show.....the calipers dont show all that much w/ stock wheels. just wanted everyones opinions and thoughts ....thanks
Red or black either color would be fine and it's really not that hard to do at all.
Here's the write up I used when I did mine
http://www.bfranker.badz28.com/fbody/calipers.htm
and here's how mine turned out
http://images.cardomain.com/member_i...234_3_full.jpg
and if you are worried about durability those pics are recent and I did the calipers about 6 or 7 months ago
-Archie
-Archie
It's very easy to paint your calipers. I think painting the calipers black looks good since it doesn't take your attention away from a good looking wheel. Here's a picture of mine.
http://www.ls1camaro.net/freehosting/wheel.jpg
Originally posted by lastZ
yeah i did read that by f franker......it looks easy , i just wanted peoples experiences w/doing it is all.......yours came out great aw/white Z-28!
BTW if you plan on doing caliper decals make sure you put atleast 2 coats of clear coat over em I did 3 coats and don't let the paint dry completely in between coats or the paint will not stick in some places.
I just might have to do this in my cars down time, and over up some trans am decals
Originally posted by blackbirdta
do u guys just put decals on the back calipers?
I did my calipers today and it was actually very simple even without taking off the calipers. Just take a wire wheel brush and go at them! Then take a dremel with a good bit for sanding and such and get the tiny areas that you cant reach with the wire wheel. Once that is done clean them off with just a towel and water really well. Once done, take your spray paint and spray it into a cup (make sure its not styrofoam or anything like that because the paint will almost immediately dry on that). Buy some cheap paintbrushes used for model cars and such. Tape off all the parts you dont want painted (only takes like 5 minutes, but will save your ***). Go over with about 4-5 coats with the brush. Let it sit about 20 minutes in between coats. Then let the final coat dry a little longer. Then you can basically just spray on the clear coat with about 2 coats. I did not use primer and it came out very easy and nice still. I am in the process of buying some decals to put on in a few days.
