Paint experts--take a look at this........
Old Jun 26, 2007 | 05:08 PM
KillerTA's Avatar
Is there anything I can do to fix this?
Some loser must've airbrushed over a scratch and now the little scratch looks 100 times worse because now there is a big area that you can tell has been painted and it looks like crap.
If I had the door clear coated, would that blend in the edges of where it was air brushed?
It looks like ****
Old Jun 27, 2007 | 07:34 PM
Lt1son's Avatar
IM not a expert at all but i think if you wet sand and buff it it will come out..it looks like something happened under the clearcoat of the car..1500grit wet sand and buff i think you will b ok..
Old Jun 28, 2007 | 01:18 AM
CamaroZBoy's Avatar
I agree with the above mentioned...try a light grit WET sandpaper....like 1500 or even some 1800 if you can find it. Make sure the area you are sanding is lubricated well and clean from any particles that could scratch it....then find a nice polishing swirl remover....grab a buffer with foam buffing pads and go to town...should hide it really well...
Word of wisdom...be gentle while wet sanding and be sure to keep ur buffer moving....I would imagine there is not much paint, nor clear coat in that specific spot...judging by the picture. If you bite through the clear coat...it will look even worse.
Cory
Old Jun 28, 2007 | 11:00 PM
Geezer powered's Avatar
Sorry Pal but the only thing that will fix that is a repaint. This is years of bodyshop experience talking. That's what happen's over time when people spot paint. There's only one way to do paint and body work, that's the right way.
Old Jun 30, 2007 | 01:47 PM
MarcR94v6's Avatar
Looks kind of like cheap clearcoat peeling up on you. My guess - someone thought they could spot paint but didn't prep right and used cheap/wrong clear and the clear is peeling where the color was spotted on.
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
92_RS_305
Sep 8, 2015 07:47 PM
