New style taillights on a 93 help
Old Dec 26, 2006 | 04:54 PM
Z Power's Avatar
Hi everyone,
I need some help converting to the newer style taillights. When trying to wire up the new connection for the new(er) harness, I could not find the blue and grey connector (brake switch) with light blue wire i need to tap into. What I did find is a black and blue harness with only 3 wires, blue, orange, and yellowish. The blue wire running to this harness does control the turn signel as light blue wire for the later models does. Does anyone have any experience with 93's wiring?
eric
Old Dec 26, 2006 | 05:24 PM
sbca96's Avatar
http://www.bfranker.badz28.com/fbody/97lights.htm
Tom
Old Dec 26, 2006 | 05:52 PM
Z95m6's Avatar
The switch mounts right up around the top of the brake pedal. Its pretty hard to miss.
Old Dec 26, 2006 | 07:03 PM
Z Power's Avatar
Thanks for quick response, but the problem is I followed those instructions and the my car does not switch that is mentioned. My brake switch is black with a blue top with only 3 wires coming out of it, blue, orange, and pale yellow. The blue wire is the wire for the brake lights themselves, the turn signals still work whether this is cut or not. There is another switch(i believe it's a switch) mounted above the brake switch with 2 wires, but the turn signals still work regardless if its harness is unplugged or not. So, does anyone else with a 93 have any experience with this?
Old Dec 27, 2006 | 05:56 PM
sbca96's Avatar
I have a 93, and the taillights, but I havent done the swap yet.
Tom
Old Dec 27, 2006 | 08:28 PM
Z Power's Avatar
just to clairify, the install guide is correct with connecting the blue wire from the brake switch to your newly ran wire, but if you look at this http://www2.phrontifugic.com:361/nflashhome.htm site (under how to), it tells you to look for a silver box with a black and gray connector with approx 5 wires. On my 93, there is no silver box, there are 2 black boxes, one above the other.The top box has 2 wires (can remember what colors) and the bottom box with 3 wires, blue orange and yellow. This is the blue wire you cut and connect to.
Thanks for all your help
Old Dec 28, 2006 | 01:21 AM
sbca96's Avatar
So you figured it out? That blue wire was the correct one?
Tom
Old Dec 28, 2006 | 09:42 AM
Z Power's Avatar
yes, the blue wire is the correct one
Jeff1904
Jun 5, 2016 05:00 PM
Ericksd
Jan 20, 2016 06:07 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
USN06
Sep 7, 2015 03:30 PM
