New Interior Mods! :)
Ok FINALLY I got all most of my interior upgrades almost done to my liking. I always LOVED the white gauge faces on the REALLY expensive GMMG and Berger Camaro's but I have tried to get those clusters.... GOOD LUCK they are about $500++ and then you have to redo the cluster computer, all of this was a real pita and REALLY discouraged me from doing this. I always thought that the white gauges with the ebony leather interior would really make it stand out and look great! So about a few weeks ago I found a seller who makes white gauge faces & HVAC and Headlight covers. (OF COURSE I NEVER REALIZED THAT 6 LITER EATER MADE THESE
) So for $35 and about 40 minutes I installed these and I think they look GREAT!
But that just wasnt enough lol. With help from a local buddy & fellow Camaro owner I ordered the LED's in "Cool White" and we installed the LED's in the odometer cluster, shift plate, HVAC, headlight switch and the door lights.
All I need to get now is a A-4 shift plate white cover and I am in the process of getting that from Mark with 6 Liter Eater.
The difference in the upgraded LED's from the stock ones is tremendous! They really look MUCH better then the "greenish" look the stock ones had. It really looks great at night. I took these pictures with my iPhone camera but I will update it with better pics using my good camera.
Here are the pics check them out!!
There are a few more interior upgrades that I want to do and I am in the early process of starting them up.
Here are the White Gauges in the Cluster and the HVAC and Headlight White Covers:
Here are the LEDs in the Cluster and the Shift Plate:
) So for $35 and about 40 minutes I installed these and I think they look GREAT! But that just wasnt enough lol. With help from a local buddy & fellow Camaro owner I ordered the LED's in "Cool White" and we installed the LED's in the odometer cluster, shift plate, HVAC, headlight switch and the door lights.
Re: New Interior Mods! :)
DAMN! That looks great. I especially like the cluster, and that glow around the needles at night is really cool looking. Those are still the stock needles right? The looks 10x better on white than on the stock cluster. I thought they were orange for a second too.
You should consider getting a trans am cluster bezel, or one of 6LE's abs/stainless ones. It'll really set off the white gauges. Only downside is having to take off the plastic lens again.
http://www.ws6project.com/user_stor/...oducts_id=1948
Very nice, The LED's look great in the pictures but have you lost the Dimmer Feature by Using LED's?? or is there some kind of kit that allows you to retain the dimming??
Currently I have Sylvannia Filament Red Bulbs in my Gauges but they are not perfect because they are not quite bright enough, one day I'll just put stock bulbs back in
Also, remind me what type of bulbs are used in the shifter and the Door Lights?
I also just added another mod on the exterior lol
wow, I didn't know the dimmer would with the LED's, I'm not an electrical engineer but is there any reason to be concerned about the LED's & the dimmer control module not working right together are possibly being a fire risk? have you researched this or have any source that addresses this issue? I would definitly be interested in doing exactly what you did but i want to know that it is safe, If you dont mind, go ahead and post the Parts list you used, I know the Gauge lights are T10's but I dont remember the Spec for the Shifter, Door, and other lights.
thanks
thanks
thanks
thanks
Badd02 Iwant those gage covers. PLEASE TELL ME WHERE I CAN BUY THEM .your cluster looks great.I got to agree with Bloody Z thatyou need either the whole bezel or just get the ss overlay. nice work looks great!
but if there was someway to fix that problem I would be all for doing it to my car. You could probably wire in resistors or something in the line from the dimmer to the lights to get them to work correctly, again I'm no eletrical engineer, but I would be worried about the lower voltage of the LED's causing the Dimmer unit to possibly overheat, i admit I don't remember how the dimmer works.
And thanks man I like the new mods a lot. They look SOOOO much better then the stock ones. DEF do it man!
Only costs about $55.
Henson071
Dec 30, 2015 09:55 PM
cmsmith
Aug 9, 2015 07:30 PM
Aug 5, 2015 08:35 AM
