Neons..
some of the cheaper versions come with transformers on the individual tubes which requires more installation work. these are often not as bright and break easier. you pay a little more for kits like streetglow but you get a brighter light and a much better warranty.
good luck.
good luck.
Originally posted by kandied91z
go to pep boys and spend 60 on a set then. won't be as bright or last as long but if that's alot right now it may be your better option.
if you have any electrical knowledge you should be fine installing it. otherwise most places will charge upwards of 125-200 for install.
the neons typically include 4 tubes and a transformer. with streetglow gold kits you run the tubes in series making a loop connecting the ends of the circle to the two wires off of the transformer. the transformer has to be grounded via a metal backing plate and a toggle switch is ran off of the "power" or hot lead wire coming out of the transformer. just fuse the switch and your done.
this is of course for on/off useage....if you want to get more tricky you can also tie it into your alarm system or i even have all of mine on separate keys to a remote so i don't have to be in the car to turn them on or off.
