Need quick headlight help....
Old Dec 17, 2003 | 09:54 PM
Brandon 95 Z28's Avatar
Ugh, my headlight is out again, and i am wondering if there is any way to get the current bulb out of the housing since I used JB Weld to seal it. My other question is will these headlights work ok with the stock wiring harness??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448879084
or should I go with these ones..
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448446815
I really want to increase my road visibility at night, and I was wondering what the stock harness will support, and if the higher ones would be safe.
Thanks!
Brandon
Old Dec 17, 2003 | 11:22 PM
Too late, bought the first ones. , guess I will see how easy it is to get JB Weld off sometime next week
Brandon
Old Dec 17, 2003 | 11:39 PM
RENE95Z's Avatar
Good luck with the JB Weld. That is some evil stuff to deal with. Unfortunately, I bet you end up getting some more lenses by the time it is all said and done.
Old Dec 18, 2003 | 07:02 AM
94BlackBowtie's Avatar
To run higher wattage bulbs in the headlights, and get all of the power they need supplied to them, run a 30 amp relay in line with the stock wiring (also with a direct power draw off the battery). The maximum wattage bulb you can safely run on the stock wiring is a 130W bulb.
Now - that does not mean you will have a good current flow necessarily. You will be able to get the full 130W of power to the bulbs, but a larger gauge harness would be helpful.
How to calculate these figures
First use this formula to find the amperage output:
watts of device/volts of source = amps (current being drawn) or W / VDC = I
Example: 55w bulb/12volts (battery) = 4.6 amps
Most people say add 20% for safety...
4.6 + 20% = 5.5 amps
Then use this chart to determine the wire guage size needed. (From Reference Data For Radio Engineers)
Gauge of Wire-------Max Current (in amps)
20------------------------7.5
18------------------------10
16------------------------13
14------------------------17
12------------------------23
10------------------------33
8-------------------------46
6-------------------------60
4-------------------------80
2-------------------------100
1-------------------------125
0-------------------------150
Old Dec 18, 2003 | 01:01 PM
ImportKILLER's Avatar
You'll be happy with those, I have them...
Do a search, I posted my website that has pics of them in my car and them vs. silverstars.
It should only be a week or so old so it shouldn't be too far back.
Old Dec 18, 2003 | 05:12 PM
pu12en12g's Avatar
Yeah those Nokya's work great ! Mine never burned out as long as I had them. I also like the Showoff Krypton/Xenon's
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Greg88
Sep 20, 2015 07:14 PM
NewsBot
Sep 14, 2015 09:20 AM
jackpawt883
Sep 10, 2015 08:53 PM
