Need Help with Wheels PLEASE!!
Old Mar 22, 2004 | 09:42 PM
4eyedride's Avatar
Posted in Drivetrain also, maybe wrong spot- anyhoo, I just bought some 02 SS wheels for my 94 Z, and the rears aren't sliding onto the hubs, fronts fit on fine. Seems like the wheel lip on the hub is to big for my rotors- should i just grind that lip of with a Dremel? Is there another way to fix this? ANy help is Greatly Appreciated!!
Old Mar 22, 2004 | 09:51 PM
95_LT1_6SPD's Avatar
this happens on almost all wheels taken from an ls1 car. You need to grind the inside of the wheel a bit to get it on. it will be much harder to grind the hub. A few mins with a dremel will fix this problem.
Old Mar 22, 2004 | 10:06 PM
4eyedride's Avatar
Yep, that's what i was thinkin, what a pain in the a$$ though. thanks
Old Mar 23, 2004 | 04:02 PM
easier to grind the hub? are you nuts??
Old Mar 23, 2004 | 09:32 PM
4eyedride's Avatar
well, i took the dremel to it, burned 3 carbide bits, but i got them on!
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
