Need help!
Old Jan 15, 2003 | 11:46 PM
Z28 97''s Avatar
Need help!
Ok I plan on getting these wheels...
http://www.billetwheel.com/Wheels/Si...timeless2.html
18 x 10 in the rear with:
285/30/18 or 275/35/18 tires.
18 x 8 in the front with:
225/40/18 tires.
My questions are:
1) What backspacing will I need to make them fit perfect on my ride?
2) Which tire sizes should i go with on the rear?
3) Is the Front Tire size ok?
Thanks for any info!
Old Jan 16, 2003 | 11:41 AM
KillerTA's Avatar
First, I would do 18x9.5 or 10 all the way around so you can rotate and it looks better. I would stick with 275/35/18 because they are cheaper and easier to find. 285 won't make much difference anyway.
+65mm is the offset i believe
Old Jan 18, 2003 | 03:58 AM
Z28 97''s Avatar
bump...
Anyone else think i should run 18x9.5 or 18x10 all the way around, instead of 18x8 on the front and 18x10 on the rear. Im leaning more towards the 18x.9.5 all the way around for rotation issues. Although I do like the 18x10 in the back though it just looks mean. Just worried 18x10 in the front might be too wide.
