My T-top Conversion Write-up
Old Nov 17, 2002 | 02:13 PM
Gripenfelter's Avatar
http://pages.sprint.ca/Conversion/files/Index.html
I still have to do the fibreglass channel corners in spring. I'll attach more pics and explain the process further then.
Any questions or anything you would like me to clarify or add?
Old Nov 17, 2002 | 02:32 PM
Erik 94TransAm's Avatar
Looks pretty good to me. I've been thinking about doing the same to my car-that's the one thing I wish my car had (I think if I had t-tops, they would never be on my car ). Good work, looks great, and thanks for the write up-it will definitely be useful. Approximately how much did it cost you?
Erik
Old Nov 17, 2002 | 02:42 PM
x7x7's Avatar
Thumbs up
Good job. The conversion looks pretty simple. Good write-up, can't wait to see the rest of it.
You should take some more pics of the car with the t-tops installed. I'd like to see how everything lines up.
Old Nov 17, 2002 | 04:04 PM
94-3.4's Avatar
When do you want to come down and do mine?
Nice work!
Old Nov 17, 2002 | 05:40 PM
Well I'm going to do the minor cosmetic stuff slowly over winter as time allows.
I'm going to use photoshop and edit some of the pics right away and add arrows etc. So reshresh the page in about an hour.
The T-tops lined up perfectly the first time.
You can adjust them by moving the brackets back and forth and playing with the washers.
I have to adjust the weather stripping a bit on the driver's side. Grind down the fabricated channel a bit more toi make a better fit.
94-3.4: Dude!! Come up here and I'll help u do it in a week.
Cost me $40cdn for tools and supplies on top of the cost of the T-tops etc.
Old Nov 17, 2002 | 06:13 PM
94-3.4's Avatar
Right on! As soon as a get a truck or when the car runs
Old Nov 17, 2002 | 06:15 PM
TheV6Bird's Avatar
Looks like a good write up to me, the instructions seem detailed and the pictures are clear.
I've always loved your hood and paint scheme, Grip.
I also love this pic from your website
EDIT: teh Copy & Paste rule ownz j0000!!
Old Nov 17, 2002 | 07:06 PM
Dave Hacker's Avatar
Very nice. Brings back memory's of my install last summer. There are a couple of things I would add.
Purchase a spot weld bit from the local paint supply store, It is a very small hole saw that is made just for breaking loose spot welds. Works much better than a drill bit IMO.
When cutting the seam across the roof stay on the front side of the seam and leave that small lip. It is a small detail that I think really looks good.
If at all possible, try to avoid riveting the fabricated sheet metal. I know that sometimes you have no choice but welding makes for a bullet proof fab job. I welded mine instead of riveting because from experience they will eventually show thru the body filler and allow the body filler to crack. I know most people dont have access to a welder but that would be the preffered way to do it
Your pictures are very detailed and the work looks great. Very nice job. If anyone is intimidated by this mod, dont be. It is not difficult. Take your time, measure twice and cut once.
Dave
Old Nov 17, 2002 | 08:49 PM
superal's Avatar
Nice work on the pictures. When I first test fitted my ttops, I was surprised at how nicely they lined up. Very easy to make them fit perfect for any of you debating to do this. For the perfect look, I purchased a trim piece from the local car place and installed it on the back groove so it didnt look like a homemade cut job.
Old Nov 17, 2002 | 11:09 PM
FilledWithFurySS's Avatar
good for you gripy!!
I am doing the same thing this summer!!
GO TEAM!!
~Mike
Old Nov 18, 2002 | 08:07 AM
I'm going to use one of those plastic door guards that people slide over their door edges to hide the "home-made" look on the cut roof skin.
Thanx for the kind words guys.
Old Nov 18, 2002 | 10:19 AM
superal's Avatar
Yea! Thats the trim I was talking about. It looks great. There isnt anything else on the car that looks homemade. It excites me I dont have pics of the trim installed yet but I have pics of everything else completed. I'll try to post them to give you a couple ideas maybe.
Old Nov 19, 2002 | 01:18 PM
JumpinJackFlash's Avatar
Hey Grip, that look's pretty cool, for T-tops. The way your top hood looked, it reminded me of the way the new Corvette roof comes off. That would be a cool idea as well.
Old Nov 19, 2002 | 10:11 PM
superal's Avatar
Hey, quick question...what did you use to plug up the holes near the windshield in the metal? I tried a hardware store, home depot, and a ricer store and none had a rubber plug big enough for that hole. Any advice on where to find one? Also, that door trim stuff works just awesome. It fits perfectly, looks factory, and it smells good too. Damn rubber plugs...
Old Nov 20, 2002 | 12:53 PM
I'm going to do the fibreglass corners this weekend or next weekend.
We'll probably fibreglass over them.
Also you can use the metal strip that I pulled off in the first step to cover the roof skin cut edge.
