mounting guages without an A-pillar
Old Sep 2, 2002 | 08:46 PM
RichJ's Avatar
Post mounting guages without an A-pillar
I'd like to mount up an oil temp and a water temp guage and have them very visible above the guage cluster so I can keep an eye on them when on the track. I can't put them on the A-pillar because I have a full cage and no longer even can fit in the factory plastic there.
Does anyone know of a pod that would fit on the dash or a good way to make one? I was thinking of taking a block of wood, my die grinder and a bunch of time and just carving one out and painting it black.
Thanks,
Rich
Old Sep 5, 2002 | 01:59 AM
aram's Avatar
Post
you could just use the auto-meter mounting pods and bolt them on top of the dash.. I had mine setup that way for a while.
Old Sep 5, 2002 | 09:49 AM
Post
This is sort of the extreme solution... and hard to see, but if you look carefully, you will see a full gauge panel at the base of the windsheild. That was made from aluminum.... the fact that the car is owned by the manager of MBA Billet may give him access to things the rest of us can't.....
http://www.malcams.com/legacy/Interior.htm
Fred
94 Formula A3+1: 381/TH400+OD/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
