More powerful headlight harness, for 125 watt bulbs
Old Mar 11, 2004 | 09:27 PM
JJJ93z's Avatar
when i got my bulbs off of ebay i mistakenly ordered they 125watt nokya's , insted of the 100watt ones. i know that with that much power going through our stock harness that it will fry. is there a bigger harness out there that could work with these lights? ANY help is appreciated. thanks
Old Mar 12, 2004 | 07:55 AM
94BlackBowtie's Avatar
Well...actually, your stock harness won't necessarily fry with 125w. Read the info on this page. Would I really recommend it - probably not...but it would be ok coming from the engineering standpoint of it.
But here is where you can get the harnesses.
Are you positive that they are 125w usage - or 125w output? I know that even Nokya has an output wattage on there. See - read the details of this auction. They are passed off as 100w bulbs - but the seller actually states..."- Giving Higher Wattage Output 100W but only consuming Wattage 80W!"
So you may actually have a 100w bulb - just trying to help you be sure.
Old Mar 12, 2004 | 03:06 PM
ImportKILLER's Avatar
If you got them from eBay and they say 125w, I would bet money that the 125w rating s output (in their opinion) and not actual rating. My FX say 120w but are really 80w bulbs.
Old Mar 12, 2004 | 03:09 PM
JJJ93z's Avatar
So you may actually have a 100w bulb - just trying to help you be sure. [/B]
alright on the bottom os the 9005s it says 100W
on the 9006's it says HB4 80W
So am i good to go with out the 30amp relay? also the 9006s have a silver tip painted on them? what is this for? and are the 9005s the low beams? hey import killa where did u get your euro clear bumper signals from? i want them!
Old Mar 12, 2004 | 03:52 PM
If that's what it actually says on the base of the bulbs - then that is the actual wattage.
Yes - you should be fine. Although a heavier harness would give you a better, more consistent flow - you should be fine on the stock harness with a 30-amp relay. BUT, know that I am not responsible for that if anything does go wrong.
The 9006's are the low beams - they have a silver tip to keep the light from diffusing as much as the high beams. The 9005's (high beams) are brighter because of this. In the stock setup - they are the same 55w - so that's the only difference (aside from the plug style).
Just noticed where you were from...
My mom lived in Kankakee for a bit when she was a little girl.
Old Mar 12, 2004 | 04:58 PM
JJJ93z's Avatar
they are the same 55w - so that's the only difference (aside from the plug style). So do i need to buy different plugs then? I really dont know that much about headlamps on these cars. or can i just follow the guide on this site?http://www.cardomain.com/memberpage/318791/5
Yeah its an alright place, I used to live In Buffalo Grove, near chicago so coming down here was a big change initially
thanks for all the help
Old Apr 6, 2004 | 12:32 PM
Highlander's Avatar
So our cars use 9005/9006 for low/highs?
Old Apr 6, 2004 | 12:35 PM
low = 9006
high = 9005
silvermansteve
Mar 4, 2015 05:02 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
phatbasslines
Jan 13, 2015 05:03 PM
siguy
Nov 27, 2014 10:07 AM
