MBA shift knob question
Old Mar 1, 2004 | 04:35 PM
germ79's Avatar
MBA shift **** question
I was considering buying the black aluminum shift **** with the bird logo shown here about 2/3 the way down the page and I have a question.
How do you know for sure that when you screw the **** on the logo will be facing the correct direction? Maybe that is a silly question, but I thought I'd ask before I shell out $40 for it!
Thanks!
Jeremy
Shift ****
Old Mar 1, 2004 | 04:59 PM
coogsLS1's Avatar
they have shims that you put inside the shift **** to make sure the logo gets placed correctly. Mine is almost perfect, very easy to do, just try a bunch of options.
Old Mar 1, 2004 | 05:54 PM
germ79's Avatar
Hmmm...that's very interesting! I figured there had to be something, but I sure as heck didn't know what it was!
Thanks!
Jeremy
Oh, do the shims affect how much of the shifter you can cut off? Is it like a spacer of sorts?
Old Mar 1, 2004 | 06:05 PM
97FormulaWS-6's Avatar
Yea, there are shims that you use... no, cut as much as you want off, they are different thicknesses, and average about as thick as a piece of paper... It's a fairly fine thread, so the thin shim makes the logo rotate a fairly predictable amount... although if it's 180* off, you may consider taking a file to the end of the rod, but that's not too hard and it doesn't take much...
Old Mar 1, 2004 | 10:44 PM
93Z286Speed's Avatar
mine lined up perfectly with no shims on a Speed Inc Shortstick
Old Mar 2, 2004 | 12:36 PM
CamaroBoy96Z28's Avatar
I have the black Z28 engraved ****. The Z28 faces me slightly and I kind of like it like that.
RUENUF
Mar 13, 2016 03:39 PM
jb4xx
Feb 2, 2015 10:00 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
redz_02
Jul 24, 2002 09:42 AM
