Left Signal Out
Old Mar 24, 2003 | 09:38 AM
jare23's Avatar
Left Signal Out
is it usually just the back bulb when my blinker light stick on and the front does light up and not blink? i just realized this last night. when i left the blinker on and stepped out to the back of my car and hit my tailight it started blinking again but didnt work this morning when i went to check it out. bulb or what?
Old Mar 24, 2003 | 12:42 PM
AW/whiteZ-28's Avatar
Your blinker is going out its under the dash just replace it make sure you replace the right one because the first one you are gonna see is the hazards
iamsparc's Avatar
Take the bulb out...re-seat it...then try it again. If that doesn't work..try a new bulb. If that still doesn't work, then you've got something wrong in the circuit. Either a blown fuse, or some other kind of weirdness.
Considering you also have a post about your interior lighting going out...and in your sig, you mention doing a mod with your electrical system and the headlights and foglights. Is there a possibility you screwed something up? (no offense)
-Mike
Old Mar 24, 2003 | 01:08 PM
jare23's Avatar
well i know the headlight mod had nothing to do with it but the overlay could have something with it. i really dont know for sure. im gonna try and change out the fuses today to be sure. but on the blinker, do you think that it could just be loose in the rear? because when i did hit it, it did start flashing again. im gonna just take off the tail light and see what i can do from in there then ill get back on here. thanks
Old Mar 24, 2003 | 02:45 PM
jare23's Avatar
i guess it was either a loose wire or the bulb was. i dont know for sure but i jiggled some things around and now its working.
Old Mar 24, 2003 | 07:12 PM
notstock4long's Avatar
I thin kti is the turn signal flasher, under the dash.
Jeff1904
Jun 5, 2016 05:00 PM
fift5
11
Oct 1, 2015 10:31 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
Aaront810
Sep 11, 2015 11:24 AM
Daluchman1974
Sep 11, 2015 06:12 AM
