LED Taillight
Old Dec 6, 2003 | 01:04 PM
PDCamaro318's Avatar
LED Taillight
Hey guys I was wondering if it is possible to convert the rear taillights to LEDs. If anyone has done this could you please assist me in getting the information as far as parts, labor, and things like that. Sorry if this is a repost but i did a search and couldnt find anything about this.
Old Dec 6, 2003 | 02:09 PM
ibanez6rg's Avatar
I've never seen or heard people talk about LED taillights on F-Body's. Maybe you should fabricate them and make some money
Old Dec 6, 2003 | 02:30 PM
Wraith's Avatar
Can't recall if it was here or LS1, but a Trans Am owner has done it. They have it listed in their SIG as well. Sorry, can't help on the part aspect.
Old Dec 6, 2003 | 03:00 PM
AW/whiteZ-28's Avatar
Why not just buy led bulbs?
www.superbrightleds.com
Old Dec 6, 2003 | 04:18 PM
I would prefer to make the whole taillight LED made up of multiple bulbs not just one bulb.
Old Dec 6, 2003 | 07:43 PM
97FormulaWS-6's Avatar
That can be done.... how much you wanna $$....
I've made my own bulbs, and am making the 2nd generation of bulbs right now. But mine are only about 2" in diameter, 6 of them..
If you're talking about making your tail lights like the Caddi ones,
Can it be done? yes
Is it "easy"? that depends on your skill level
Will it be cheap? Depends what "cheap" is
If I were to make a set for someone else it'd probably cost atleast $200-$300. That's for mostly just parts, and LOTS of labor...
Here's my idea if you want to see what you can do with the Camaro Lights:
You'll need ~250-500 5mm Red LEDs, A Piece of material you can make a PCB out of large enough to fill the tail light, And I'd use a Piece of Acrylic to support all the LEDs, and balance the light out somewhat. Ontop of that you'll need a bunch of resistors to limit the current in the LEDs.
Setup your tail lights with 6 LEDs connected in Series, wire in a 100 ohm resistor in each string, and just repeat that over and over and over again. You've got a LOT of soldering to do.
That's probably something similar to what I may do for Gen 3 of my tail lights, Gen 2 is just a newely designed bulb with better LEDs in it.
Old Dec 6, 2003 | 10:16 PM
6Speed's Avatar
My buddy Jason converted the entire taillight assembly of his 3rd gen to LEDs. He drilled tiny holes perfectly in the lens and the LEDS stick through the lens. He covered over them with blackouts. It looks similar to the Cadillac taillights. I can put you in touch with him if you want..
Old Dec 7, 2003 | 10:35 AM
Brent94Z's Avatar
Super Moderator
My old 95 Trans Am now has all LEDs for taillights
http://www.bfranker.badz28.com/misc/cleartails01.jpg
http://www.bfranker.badz28.com/misc/cleartails02.jpg
http://www.bfranker.badz28.com/misc/cleartails03.jpg
http://www.bfranker.badz28.com/misc/cleartails04.jpg
http://www.bfranker.badz28.com/misc/cleartails05.jpg
http://www.bfranker.badz28.com/misc/cleartails06.jpg
Old Dec 7, 2003 | 12:18 PM
blacksix's Avatar
I found this particular website does exaclty what you're looking for..... but they're not cheap. Click on "Current Projects" to see all the different applications they've turned into LED tail lamps. I was considering having this done to my tail lights, but it's a bit pricey. Surely someone on this website can do it for us f-bods.....
http://www.clearcorners.com
Old Dec 7, 2003 | 12:24 PM
ucnu112's Avatar
Brent, I seem to remember seeing a write-up on how to do the led conversion somewhere, but I didn't see it on your 'how-to' site. Do you happen to know where it is?
BTW: sending you email on some vinyl graphics.
Fred
Old Dec 7, 2003 | 03:55 PM
Brent do you have any night time shots?
Old Dec 7, 2003 | 04:43 PM
Brent94Z's Avatar
Super Moderator
Fred
Nope, I have no write-up on that. Basically, they are stock taillights that have been taken apart and the red plastic removed. After the red plastic was removed, all bulbs were replaced with LED bulbs from AutoZone. The outer most bulbs were not available in the LED style so the socket was changed out to the dual filament type sockets which allowed for not only the use of the LED style bulbs but also allowed the outer bulbs to now brighten when the brakes are applied (ran a couple extra wires).
I'll shoot you an email back about the graphics. Thanks!
Brent94Z's Avatar
Super Moderator
Sorry, no night shots
Old Dec 7, 2003 | 05:21 PM
ucnu112's Avatar
That's what I wasn't sure about. I didn't know if they were 'pre-made' bulbs, or LED's that you bought and soldered together, etc. Thanks!
Fred
Old Dec 12, 2003 | 04:07 PM
BlueTPI's Avatar
it can be done
Well it's just a matter of how much time and/or money you want to invest.
I've done rear marker lights and a 3rd brake light for my 90 Formula, I think I may try the tail lights next(gonna take alot of LED's)
Here's a pic of my marker lights(anyone can email me if they want any more pics or info) BlueTPI@aol.com
