INterior ideas.... Need some help
Ok, what can I do? All I have is the Plane-Jane Camaro interior, w/ the T-top Sub Box Dual 12's in the rear. Nothing that will add too much weight.
Would the TA Gauge Bezel/outline work on the Camaro Gauges? -Was thinking of Chroming it.
Chroming it is damn near impossible because it and the clear lens are one piece...
You can do what I did though:
http://www.ls1tech.com/forums/showth...t=chrome+bezel
Why don't you have a custom gauge cluster panel made? You just need to find a fabricator with the right measuring & cutting equipment, then buy the gauges of your choice. I don't have pictures yet, but I had a fabricator make me a custom panel for my 12 digital gauge setup. Unfortunately, I've got the 93-96 interior, so he could only squeeze 4 gauges in there (he could have done 5, but it looked too crowded). So, I bought an overhead console dual-gauge pod (modified it to fit a Camaro) to relocate 2 gauges, then I'll be moving my a-pillar gauges to the top dash dual-gauge pod, then putting the 2 dash gauges that wouldn't fit in the gauge cluster into the a-pillar dual-gauge pod. To make "lemons from lemonade" I had the fabricator make space & cut a 0.75" hole in between the tachometer and speedometer to house a "built-into-the-gauge-cluster" Auto Meter mini shift light. with the 97-02 interior, though, you shouldn't have any problems fitting 6 aftermarket gauges in place of your OE cluster...
Henson071
Dec 30, 2015 09:55 PM
