INSTALLATION - HOOD PIN KIT for 96 SS
Old Jan 12, 2008 | 05:35 PM
dutss707's Avatar
Smile INSTALLATION - HOOD PIN KIT for 96 SS
Anyone please advise me where and how a Hood pin kit for my
96 SS should be installed...Thanks
96SS/Red w/black Ttop/full race suspension;58mm TB HOlley
Racetronix fuel system/PCM Madtuner/ 3000 vigilante et.etc.
too much to list.
Old Jan 13, 2008 | 11:16 AM
Z95m6's Avatar
please don't butcher up an OEM SS hood for hood pins.
Old Jan 13, 2008 | 02:48 PM
always faster's Avatar
^^^^^Totally agree.
Hood pin shouldnt be installed on a oem SS hood.
Old Jan 13, 2008 | 05:18 PM
dutss707's Avatar
Smile INSTALLATION-HOOD PIN KIT for 96SS
Thanks for your appropriate concerns, I would not be that
callous to do what you think I would do...No. This is for a
Fibreglass SS Aftermarket hood. Thanks very much... Please
advise where/how to install kit...Theo
Old Jan 13, 2008 | 05:31 PM
6SpdLT1Z's Avatar
Old Jan 15, 2008 | 08:34 AM
blackbirdta's Avatar
i have a suncoast ss hood with pins and I desperately want to paint my black oem hood blue to get rid of those fugly hood pins
in other words I'm no help either...
Old Jan 15, 2008 | 09:05 AM
shock6906's Avatar
Does your hood use the OEM latch in the front?
Old Jan 15, 2008 | 11:50 AM
Z28SORR's Avatar
Two things theory and practice.
In theory there should be at minimum, four pins and they should be in the best location to support the largest area. That's usually 1/3 in from all four sides.
In practice this usually puts the pins in locations where there is no supporting "frame" for mounting. And it's not the most esthetic (best looking) locations. So most people compromise and place them as near to these (1/3) location as possible. A common mounting location is the radiator support frame. It's back far enough from the front edge to give good hold down and still looks pretty good.
Out side of these general guide lines there's lots of different ideas. On my '84 I fabricated mounts that went from the front fascia to the rad. support so I could get the pins in a more ideal location. Some people use a simple rear hinge and only install front pins. Other have found that pins alone aren't enough and install Dzus fasteners around the edges of the hood. All depends on the "wieght" of the hood and your speed.
Old Jan 15, 2008 | 12:59 PM
it latches exactly the same as every other hood, but it has "pins". They aren't actually pins, but locks to lock the hood down......so no one can steal my engine?
I hate them...
Old Jan 15, 2008 | 01:59 PM
shock6906's Avatar
I hate them...
My question was a set up dependent upon his reply.
CARiD
Jan 27, 2015 06:27 AM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
Don 97 SS
Jul 11, 2005 08:50 AM
