If you've put LEDs in your gauge cluster please enter!
Old Jun 19, 2003 | 09:20 AM
SloMofo's Avatar
Arrow If you've put LEDs in your gauge cluster please enter!
I recently put the quad LEDs in my gauge cluster.
It looks like crap, though. Only the parts directly in front of the bulbs are lit up good. The other areas are very dim. Especially the Oil press & temp gauge sides
I tested all bulbs before installing so I know they all work.
I have Macewen overlays on as well if that matters
Old Jun 19, 2003 | 09:42 PM
catsnet's Avatar
http://members.rogers.com/ochitkov/Trash/Image52.jpg
http://members.rogers.com/ochitkov/Trash/Image68.jpg
http://members.rogers.com/ochitkov/Trash/Image42.jpg
http://members.rogers.com/ochitkov/Trash/Image58.jpg
Have them for almost 2 years. very bright and never had any problems with fading or burning bulbs
Old Jun 19, 2003 | 09:46 PM
Ferocity02's Avatar
240 mph
Old Jun 19, 2003 | 10:07 PM
catsnet's Avatar
Originally posted by Ferocity02
240 mph
Old Jun 20, 2003 | 06:36 AM
SloMofo's Avatar
Yea, I've seen your's before. They look great. I don't understand why mine look like a$$
Old Jun 20, 2003 | 06:39 AM
94BlackBowtie's Avatar
Slo - What kind of LED's did you use? Quad tip, or one big one?
Old Jun 20, 2003 | 07:53 AM
SloMofo's Avatar
It says Quad in my 1st post
Old Jun 20, 2003 | 10:28 AM
mobleman's Avatar
I have the quad tip bulbs also, same result as you. the single tip bulbs are supposed to disperse the light better, the end of the bulb is concaved which results in a broader light beam.
I plan on getting the clear 5 watt 194's once they are available.
Old Jun 20, 2003 | 10:52 AM
I know
I was just kidding...
I didn't see that, but...normally the quad LED's do pretty good - they seem to be brighter than the single type...
I think that is what catsnet has too...is the correct Alex?
Old Jun 22, 2003 | 12:26 PM
SloMofo's Avatar
Old Jun 22, 2003 | 01:41 PM
Dark Angel's Avatar
On my '01 I had to use a mix of the single dish shaped LEDs and the Quad tip. I the Actual Speedo and Tach, I used the single LED, is it seemed too bright in areas and on the outside edges I used the quad tipped. I made the lighting a little more uniform.
Old Jun 22, 2003 | 03:44 PM
30thZ286speed's Avatar
Where do you get LEDs for the dash?
SloMofo's Avatar
www.superbrightleds.com
Old Jun 22, 2003 | 08:53 PM
z28_melissa's Avatar
It's because you bought the quad ones - trust me. Buy the single LEDs, the light spreads out instead of pointing in one direction like a laser pointer
Here's my dash with the blue single LEDs from superbrightleds.com:
http://users.tc3net.com/prielipp/glowygauges.jpg
And a diagram I made:
http://users.tc3net.com/prielipp/labeledbulbs.jpg
Old Jun 23, 2003 | 10:27 AM
SloMofo's Avatar
I'm gonna order those and see if it's any better
