I dont get it...STUPID SS Spoiler =)
Hey guys,
I have a 98+ SS Wing and i had the ABS INOP problem like every else...
(Its mostly my fault....)
But when i bought the wing, i never hooked up the third brake light wiring to the Wing...cause i just figured that the ABS light was gonna be on anyways...
Sooooooo...today i bought a 12 volt relay and some female connectors b/c i found an easy write up that i had like a year ago on how to fix the ANS INOP problem.
As i open up both packages, i hook up the third brake light wiring from the wing to the wiring from the car and......
the stupid light went off. I just wasted money b/c i was an idiot
Anyone not fixed thier problem and want to buy the relay and connectors off me?
I'll sell it cheap! Can i do anything else with the relay?
Anyways, has anyone in a 94 put on a 98+ SS wing , have the same thing happen, where u just hooked it all up and it worked perfectly??
Wow that's strange ! I just figured I'd try it out and wired my 96 Z straight up on the original install and my light has NEVER come on. I just ASSUMED it was because of the OBDII computer in the 96 cars but your OBDI series 94 blows that theory to hell!!! I've helped a couple other guys with 94/95 cars with the relay wiring deal you have since their light wouldn't go out until the relay was added. ???????
Originally posted by AW/whiteZ-28
Watch after you sell that stuff the light will come back on lol!
I better just hold onto it then. I just hope u didnt jinx me
j/k!
But yea, i was suprised as heck. I have no idea why it worked? Hopefully it stays like that.
Mach5 - you just had to be negative didn't you...
When I put my SS spoiler on (it will be a '94 also) I plan on doing a better write up than what anyone else has ever done. I don't know how long that will be now, but sometime before long hopefully.
What amperage is the relay you bought? There are a couple of things you could do with it, if interested.
94BlackBowtie Mach5 - you just had to be negative didn't you...
I figured I would let him know to try and turn on the 4way flashers to see if the light comes back on, before he gets rid of the relay.
He posted asking if this had happened to anyone else and I responded.
you all ac like a bunch of 3rd graders, you get all upset just because someone said your being negitive and then someone has to explain they were joking around. like a bunch of inmature children. don't take it personally, i see everyday on here.
mlopezart
Sep 8, 2015 12:15 PM
Henson071
Aug 4, 2015 09:32 AM
