Did the headlight conversion lastnight
Old Feb 21, 2003 | 10:36 PM
witchcraft's Avatar
Hi, I did the headlight conversion like everyone else. I just wanted to say the I bought a full set (4 Bulbs) on Ebay for 19 buck. Go to http://cgi.ebay.com/ebaymotors/ws/eB...403272811&rd=1 to see them. They worked and the sealed beam conversion was not as hard as I thought it would be.
Old Feb 22, 2003 | 04:31 PM
Roshambo's Avatar
Interesting. Do you have any pics of them on your car or anything?
Also, what all was involved in the conversion? The reason I ask is because is because my headlights SUCK!
-Joe
Old Feb 24, 2003 | 12:16 AM
witchcraft's Avatar
Hi, no pic yet. I don't have a digital camera so I have to take Poloriods and scan them in.
The conversion was easier than I thought it would be. I did it in the middle of the night in the rain. What you do it take out the stock headlight remove the bulb from the housing.
The stock headlight is glued to the housing from the factor so removing it can be tuff. It is also under a slight vacume. I put tape around the before I tried to remove it, so it I broke it it would not shater.
You can pry the bulb from the housing with a flat screwdriver, place a cloth under the screwdriver to prevent breaking the glass housing. Slowly pry around until it starts to come apart, you will hear a little puff as the pressure is released.
Once you get the old bulb out everything else is cake. Glue the new bulb in with RTV selent and tape the bulb to the housing while the selent sets up. Then put the housing with the new bulb back into you car and you are set.
The lights look a lot better than the factory lights.
I hope this helps.
Old Feb 24, 2003 | 07:22 AM
Vokabulis's Avatar
do you like the "conversion?" I did it to my car and it looks cool with the blue color but the quality is very bad. I can't see anything with them. Even wose than stock. Not the mention they aren't DOT approved.
Old Feb 24, 2003 | 09:56 AM
94BlackBowtie's Avatar
Here is a guide to the conversion for those interested...Very excellent guide...
This is more like a modification than a "conversion." You will never get a really good output with it. But I will say, I achieved a better than stock lighting output, but it wasn't with any of the highly tinted bulbs (blue, purple, etc.) The best output you are going to get with this setup is the Sylvania Silverstars. The bulbs you bought witchcraft are probably a simlar type bulb. The next upgrade is better housings.
Old Feb 24, 2003 | 10:13 AM
pu12en12g's Avatar
Yeah I wouldn't call it a conversion either, if you just swapped out the bulbs
Old Feb 24, 2003 | 11:06 AM
silver97Z's Avatar
witchcraft...
Are you from Barboursville, WV? If so, I live out on East Pea Ridge
If not...welcome to the board anway!
Old Feb 25, 2003 | 03:29 PM
witchcraft's Avatar
Lightbulb
Hi, I am from barbourville Ky.
I like the way my lights looked and I could see much better. Of course you are not going to get the same results as the real HID conversion setup which is like $500+ for 19.99. But seeing how it cost 20 bucks and takes about an hour or so to install I think it is worth it.
Old Feb 25, 2003 | 04:15 PM
Roshambo's Avatar
Yeah, I think that is the route I am going to go with also. I saw a commercial for them on Speed and while the whole damn time it was these idiot's trying to rap about them they look like a great product.
Anyone have any before after pics of the Silverstars?
-Joe
Old Feb 25, 2003 | 06:29 PM
BofromWNC's Avatar
Which Silver Stars to use?
Which bulb do you use, the 9005,-6, or -7? '98 up lowbeams in the '97 back housings, and same for the highs?
Old Feb 25, 2003 | 07:14 PM
guess1's Avatar
Post
I recently got the Sylvania Silverstar bulbs and did all 4 (cost around $100). It took about an hour and a half of work, very easy to do, and you do get a noticeable sight distance improvement, although it ain't gonna be like HID, but the lights are very white so now my fog lights look dull and yellow.....time to upgrade those too. It is worth the $ in my opinion to be able to see farther.
Old Feb 25, 2003 | 07:46 PM
notstock4long's Avatar
So without the brights on do these still look more whit/blue than stock lights?
Old Feb 25, 2003 | 07:53 PM
guess1's Avatar
Yes. All 4 are equally white, but the high beams are just brighter. They do not have any bluish tint to them, so they don't look like fake HID's.
Old Feb 25, 2003 | 09:56 PM
Xride's Avatar
how much better can you see with this done over stock?
one thing I have noticed is thats its about impossible to not overdriver your headlights.
Old Feb 25, 2003 | 11:02 PM
witchcraft's Avatar
Which bulb
I used 9006 for the highs and 9005 for the low. I have heard that it is better and brighter to use the 9006 for both, because the 9006 are 100w and 9005 are only 80w. I did mine this way because I bought the lights as a set and this is how they came.
