I bought a new Flowmaster 40 series muffler?
Old Sep 27, 2002 | 09:15 PM
95FormulaMark's Avatar
Im having it installed at Mienike muffler.It needs to be welded in.Are there any things I should look out for?....Mark
Old Sep 27, 2002 | 10:33 PM
Megalis's Avatar
40 series? why not 80? 40 is way to tame I think. Meineke will problably charge you to much and wait way to long for a 15 minute job.
Old Sep 28, 2002 | 08:51 AM
TheV6Bird's Avatar
This should be in LT1 Tech, but I'll give you some pointers
What are the inlet and outlet sizes? Try to get them to use a 3 inch pipe for you tailpipes, and you MUST tell them that. I just assumed, so now I have 2.25 inch tailpipes! Of course if I went back, the bastards would've charged me extra to fix it, and for a V6 like mine I just said "Screw it!"
With a 40 series, you will only have one tailpipe. The 80 series is what gives you the dual outlets. If you decide to return your 40 series and get an 80, make sure you tell them where you want your tailpipes to exit under. The guy I had put them WAY to close to each other, not spaced out enough. "I've always loved the way tips looked when they are closer." He said. That's nice, but It's MY CAR!!!
Good luck on your install. I'd recommend the 80 series, just because the symetry of a dual exhaust looks better than just one tip underneath, IMO.
Old Sep 28, 2002 | 11:49 AM
Flowmaster just arrived.
My mistake it is an 80 series. Im using the original tailpipes and tips,Whatever size those are.......Thanks....Mark
cmyname1
Feb 19, 2015 08:38 PM
ModdedNerd
Feb 5, 2015 04:37 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
stanghunter211
Aug 29, 2002 03:04 AM
TheV6Bird
Aug 27, 2002 10:38 PM
