HVAC Bulbs
Old Sep 14, 2003 | 04:11 PM
ut's Avatar
ut
HVAC Bulbs
What size bulbs are needed for the HVAC control lighting on 93-96 Camaro? Are they the same 194's used in the instrument cluster? I would like to use colored bulbs if possible. Thanks.
Old Sep 14, 2003 | 04:47 PM
AW/whiteZ-28's Avatar
They are the same size as the ones that illuminate the door locks
Old Sep 14, 2003 | 08:16 PM
94BlackBowtie's Avatar
Not 194's, and not available in colors.
You can replace them though - pretty easy too - just a pain to get the old bulb out of the socket. (Hint: Use some duct tape).
They are and bulb with the "_7" number - the "_" usually a 6 or 9 or something. Any will work, and I think it is the higher the number, the more wattage. Available anywhere automotive lights are sold.
Old Sep 14, 2003 | 09:07 PM
ut's Avatar
ut
Would LED's fit right in?
Old Sep 15, 2003 | 08:08 AM
Well - I may have to rethink my original reply.
See this current thread. It tells all about LED's - and it seems that there may be a possibility there for some direct replacement led's - but not just a regular 3mm will fit in without modification - see that thread.
cmsmith
Sep 14, 2015 09:25 PM
4586
Aug 24, 2015 11:04 PM
ReznorZ28
Aug 28, 2002 10:02 AM
