how to take off headlights and turn signals?
anyone know how to take the turn signals lights and covers off also the head lights? havnt really looked at them but would like to know alittle about it befor just jumping right in and tearing things apart. thanks
The turn signals have to be taken out from the underside of the car. Remove the black panels under the nose and look up. You'll know what to do from there. For the headlights, you just take the screws out of the black metal retainer rings. The lights themselves aren't held in with anything other than that. This is for LT-1 cars...I don't know about LS-1's.
Yep what shock said, but you better have some long skinny arms getting those turn signals out...my recommendation to you would be to buy a Haynes repair manual-definitely worth the $17....they are really helpful just don't trust all the tq specs they give you. Take your time and don't force anything
The bolts to remove the black panels are 10mm and the bolts that hold the turn signals on are 7 mm....
I can't remember the torx bit size though...
weather sucks
this weather sucks a$$ so i kinda have to buy a new driver side turn signal again..... heres the story drove to work with the t top off and worked for a lillte bit camer back outside couple hours later fyi t top was back on befor i went to work. roads were compelety iced over went around a corner and slid into a pile of snow ice mixture and busted my turn signal and low beam headlight switched the headlight when i got home was real easy 3 bolts but now got to take apart the bumper again....... fun stuff
stangspank
Nov 13, 2015 01:02 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
