How to remove corner lights
clear corners:
undo the bottom plastic part under the area that the corner lights are in
reach ur hand in there
unplug the lights, by twisting them out
for me, a 97 camaro, there were 2 screws (pointing towards the front of the car), unscrew these
carefully lift up and back, and swivel around the corner light assembly, and remove, u'll see what i mean, its not that hard, i found...
install is reverse
honestly, it took me 1 hr to do at 1st, now i can swap them in 15 mins (had to send original clear corners back, as they were cracked)
good luck, they look AMAZING on black cars, also are u using the orange bulbs or white ones?
install is reverse
Caps94ZODG
10
Sep 9, 2002 12:08 AM
