how to remove bulb above power lock switch?
How do you remove that bulb that is just above the power window and door lock switch?
I removed the gray plastic cover around it and tried pulling on the wires some and also tried pulling on the bulb but couldnt get it out.. How does it come apart?
yeah I have the door panel off.. but looking at the actual bulb... does it come out of that plastic piece or do the wires come out of the plastic piece that the bulb sits in to remove it.
I've never been able to pull the bulb outta those damn things in the past, is there a trick to it? I used to go looking around junkyards all the time and would cut a good harness and bulb out of another car and cut the one out of my car and then butt connect the good one in.
Can you buy that bulb at somewhere like AutoZone or does it have to be ordered through a dealership?
In a 1996 Camaro, the interior door handle replacement bulb is a #74. You can get it at any auto parts store.
It does pull out of it's socket housing.
To remove the bulb/socket housing assembly from the door handle side panel, all you have to do is twist the socket assembly (1/4 turn if I recall correctly).
Jan 23, 2015 01:13 PM
