how to polish borla exhaust tips
Old Nov 10, 2004 | 04:16 PM
ponykiller z28's Avatar
my borla tips are getting faded and old lookin... what do you guy use to shine em up??
Old Nov 10, 2004 | 05:03 PM
Kataklysm's Avatar
Re: how to polish borla exhaust tips
Metal polish Mothers works good.
Old Nov 10, 2004 | 05:10 PM
87DJP2001's Avatar
Since they are Stainless Steel, just use a very fine grit sandpaper to get as much shine as you want. Less work then polish.
Old Nov 11, 2004 | 12:36 AM
sandpaper??? hmm... i'd be afraid i'd put swirls all over them... i guess maybe if it was REALLY fine
Old Nov 11, 2004 | 01:37 AM
Z95m6's Avatar
just use some metal polish. If you want to you could take super fine steel wool to it and that would cut about anything off of it.
Old Nov 11, 2004 | 07:35 AM
Geoff Chadwick's Avatar
Polishing metal is easy- but time consuming.
Start with like 200-300 grit (rough casting like your water pump) and work through 400,600,800. Each time once the finish is uniform and smooth, moving up a grade. Then get some rouge (like brown for aluminum) and a polishing wheel from the hardware store and have fun. Then wash the part, get some white finishing rouge and another wheel. Dont mix more then one rouge on a wheel.
Then to keep it clean and such (borla already should be i think) use some metal polish as mantioned above.
Todd's writeup which I used and have pretty much the same results (I could fix my hair using my filler neck) http://groups.msn.com/Camaro2001SS/polishinghowto.msnw
Old Nov 11, 2004 | 10:40 AM
ok thanks guys i appreciate it
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Feb 17, 2015 08:12 PM
Eddie Z-28
Sep 4, 2002 11:58 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
