How much POR 15 should I buy?
Old Mar 11, 2007 | 09:35 PM
x2jesse1x's Avatar
Im going to be buying some POR 15 when I redo everything under my car to get rid of all the rust. So Im wondering how much to buy? I want to do the entire underside of the car and some inside. Flood pans. ETC...
thanks
Old Mar 11, 2007 | 09:36 PM
mdacton's Avatar
Where do you get the stuff from? I would like to do about the same thing you want to do
Old Mar 11, 2007 | 10:29 PM
x2jesse1x's Avatar
I found it online, Just yahoo.."POR 15"
Its like 135 a gallon
Old Mar 11, 2007 | 10:30 PM
LT1 POWR's Avatar
I hear that a little goes a long way, but I have no idea on an actual amount.
Old Mar 11, 2007 | 10:40 PM
mdacton's Avatar
www.por15.com
It would take alot of work to do the whole underside, whats the best way to apply it? could it be sprayed
Old Mar 11, 2007 | 10:43 PM
danhr's Avatar
u can spray it on or brush it on.... most opt to brush it on, do avoid overspray
Old Mar 11, 2007 | 10:44 PM
mdacton's Avatar
if you brush it I could see it going a long way....if you brush it does it lay dwon flat like an oil paint?
this may help http://www.por15.com/s.nl/it.I/id.7/...=682&fromsla=T
a gallon covers 100 sq ft. so that should be more than enough
Old Mar 11, 2007 | 10:50 PM
danhr's Avatar
can't remember.... try searching for it.... i know a guy on the boards coated his entire under carriage with it.... he said it took a lot though....
Old Mar 11, 2007 | 11:48 PM
kingman109's Avatar
thats a quart gallons usually good for 400 their listing 350 -
Old Mar 11, 2007 | 11:58 PM
x2jesse1x's Avatar
jesus so Im guessing a gallon would be fine
Old Mar 12, 2007 | 12:52 AM
kingman109's Avatar
just keep in mind they reccomend 2 coatings-
Old Mar 12, 2007 | 08:40 AM
shock6906's Avatar
I painted the inside of a 62 impala bumper with that stuff. I ended up using about a quarter of a pint to do the whole thing. That was using a brush. It really does go a long way.
Old Mar 12, 2007 | 06:21 PM
x2jesse1x's Avatar
350 Square FT...I would say that its enough to do more then 2 times.lol
Old Mar 13, 2007 | 01:51 PM
klrz28's Avatar
POR is awesome stuff just make sure you prep it exactly how it says. We did a whole chasis and looks bad ***. We sandblasted it down to metal though.
warmeck
Jul 17, 2015 01:36 PM
cmsmith
Jun 4, 2015 07:35 PM
NewsBot
Jan 8, 2015 11:29 PM
