How to mount hella FF75 as fog lights?
Old Sep 13, 2006 | 08:49 PM
Fbody1's Avatar
how have you mounted your ff75 as a fog light. any pics of brackets or drawings of brackets? not to worried about what I will need to cut or trim. or any ideas?
Old Sep 15, 2006 | 12:15 AM
Bud M's Avatar
Re: How to mount hella FF75 as fog lights?
You can make new brackets from flat stock. Use cardboard to make a template using the same holes that the stock lamp brackets bolt to. Get a piece of aluminum sheet 1/8" thick or so. 12" square will be plenty. Each bracket needs to be about 4 x 5 inches. 2 bolt holes to attach to the car, one for the light bracket. Use washers to square the lamps up to the bumper openings.
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
30thZ286speed
Aug 3, 2002 04:54 AM
