How to mount hella FF75 as fog lights?
how have you mounted your ff75 as a fog light. any pics of brackets or drawings of brackets? not to worried about what I will need to cut or trim. or any ideas?
Re: How to mount hella FF75 as fog lights?
You can make new brackets from flat stock. Use cardboard to make a template using the same holes that the stock lamp brackets bolt to. Get a piece of aluminum sheet 1/8" thick or so. 12" square will be plenty. Each bracket needs to be about 4 x 5 inches. 2 bolt holes to attach to the car, one for the light bracket. Use washers to square the lamps up to the bumper openings.
