How To Make Clear Corners Fit...
Old Apr 4, 2005 | 09:50 PM
Slayer63b's Avatar
I just got my clear corners today and they look like the worng ones. I geuss they are the same from 93 to 02 . And all the ones on E-BAY look the same as mine. Is there something wrong with them or do I have to modify them? I will try and put them in tommorrow so if any knows anything I would be greatful for there help .
Old Apr 4, 2005 | 10:19 PM
neonblack's Avatar
Re: How To Make Clear Corners Fit...
I bought mine off of ebay as well. They fit like a glove. I will say its a tight squeeze to get them in there, but they should fit nicely. Just remember to take off the headlight assembly, so you can maneuver in there.
Old Apr 4, 2005 | 10:23 PM
AW/whiteZ-28's Avatar
They look like the wrong size but they aren't you'll see how it works when you get your old ones out.
Old Apr 4, 2005 | 10:26 PM
Slayer63b's Avatar
Alright, thanx. They just looked big and different to me.
Old Apr 4, 2005 | 10:56 PM
Tair's Avatar
yea, Slayer....you have to get under the car and unbolt the large triangular-shaped plastic pieces. There is one big trianglular plastic piece on each side, each one is held up by 7 tiny bolts total i believe. Once you take off this piece, slide yourself all the way under the car and take a look at the corner lights from behind the bumper, and you will easily see how they fit. It should only take you 1 hour to do both sides at the most. have fun!
Old Apr 5, 2005 | 08:23 AM
neonblack's Avatar
Just an FYI, there are only 3 srews holding each corner piece. Once you remove the headlight assembly, you will easily see them. Two screws fasten from behind, and one from underneath. The corner also has two lights in the assembly.
Old Apr 5, 2005 | 11:56 AM
Z95m6's Avatar
I think LS1 guys go in from the headlight area. When i did mine on my 95 i just removed the black plastic pieces under the car and got it that way. Its the ones that are removed when working on a CAI.
Old Apr 5, 2005 | 04:04 PM
NOS2006's Avatar
I have a v6 and I did it from the top by taking the headlights out...
brandboZ28
Jan 31, 2003 06:19 PM
silver97Z
Sep 11, 2002 03:17 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
mysticslp2002
Jul 29, 2002 02:03 PM
