How do i remove the Trans Am ground effects?
Old Jan 12, 2003 | 10:44 PM
Black94mula's Avatar
I want to remove them so i can repaint them. Are they somehow attached to the front fenders? If so how do i get at those bolts?
Old Jan 13, 2003 | 04:16 AM
v7guy's Avatar
If they are anything like the firebird GT gfx then they are held on with steel clips, plastic rivets and some steel rivets, with a row of screws going along the bottom side
There should be about 8 screws on the bottom, thsee will just nscrew from the car, there are two plastic rivets at the front and rear fenderwell lips you'll have to drill those out with a drill and get replacements from GM, there real cheap.
After that you'll need to lift up on the gfx as it is pinched in between a steel bar and the rocker panel, it will be hard to pull off so keep this in mind
Airplanedoc
Parts Wanted
Apr 18, 2015 04:22 AM
Collector Car
Jan 5, 2015 10:58 AM
troywg
Sep 12, 2002 07:28 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
