HIDs r in
Old Jan 18, 2008 | 03:37 PM
  #16
dalynchmob's Avatar
Thanks vicious. I did a little more research online and figured, since mine still have a filament, they are xenon gas filled halogens. Anyways i'm happy with em and they are way brighter than the stockers for sure.
Old Jan 18, 2008 | 04:34 PM
  #17
Vicious95Z28's Avatar
Glad to help.
Old Jan 19, 2008 | 12:16 AM
  #18
bighash007's Avatar
Hey Vicious95z28,
I was wondering the website you posted: http://performanceworks1.com/headlightmod.htm would you recommend i change the wiring harness? Do they make a standarized wire harness or can you upgrade? thanks ah billion
Old Jan 19, 2008 | 01:28 PM
  #19
Originally Posted by bighash007
Hey Vicious95z28,
Umm, I'm not 100% sure what you are asking so I'll hit a couple of points. If yu use 9005/9006 replacement bulbs with this mod then you factory harness will plug directly in.
You can buy upgrade harnesses. Some are simple and you cut the connectors off the ends of you harness and then solder or use butt connectors to add the upgrade harness or there are more costly/fancier versions that just plug into your harness and into the back of the bulb.
I also think that there are setups like would be used on mid 90's GM trucks that are upgrade harnesses with a relay and a bunch of Jazz. It's supposed to be the best but I really don't know that it would be necessary.
Old Jan 19, 2008 | 03:18 PM
  #20
bighash007's Avatar
thanks, i was just trying to get a brighter light on the low/high beams and i saw your website and was wondering if i should change the wiring harness so the bulbs wont burn out the manufacture wire (1997 camaro rs)
Old Jan 24, 2008 | 11:53 AM
  #21
ChevyLT1Camaro94's Avatar
Originally Posted by Vicious95Z28
Yeah, that's how I did the 9005/9006 conversion on mine. If some1 cwould start to manufacture a euro clear headlight the same size as ours with 9005/9005 fittings in the back I'd be in. An hid conv. on those would rock!
dude, ledgauges.com
Old Jan 24, 2008 | 04:30 PM
  #22
Originally Posted by ChevyLT1Camaro94
dude, ledgauges.com
Yeah, I'll do the conversion but I'd love to have euro clear housings, nobody makes those.
Old Jan 24, 2008 | 06:52 PM
  #23
BlackbirdWS6's Avatar
Those HIDs look good.
For the TA owners, I am selling my kit here. Comes with the conversion housings and hi/low beam kit. Very low hours and worked very well. Much better lighting.
https://www.camaroz28.com/forums/sho...d.php?t=573529
Brian
Henson071
Dec 30, 2015 09:55 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
