help on removing steering wheel
Old Sep 22, 2006 | 10:22 AM
jldak318's Avatar
Question help on removing steering wheel
on a 95 t/a. i want to remove the steering wheel but im afraid the airbag will go off. how do i remove it without making this happen?
Old Sep 22, 2006 | 10:44 AM
CrazyJim's Avatar
Member
Re: help on removing steering wheel
hit the front of your car with a hammer first... then it won't go off in your face
Old Sep 22, 2006 | 11:10 AM
Mr. Wolf's Avatar
you have to have the air bag go off don't you?, but the safest way to set it off is to find the yellow wires and connectors under the dash put on some safety goggles and ear protection and start messing with the wires.
Old Sep 22, 2006 | 04:41 PM
Rebelphotog96's Avatar
Are you F'n serious? lol Just disconnect the battery and pull the airbag fuse. Here's a writeup you can kinda go by...quite simple, but still be careful...anything can happen.
http://www.thirdgen.org/airbag
Old Sep 22, 2006 | 07:22 PM
Mr. Wolf's Avatar
but u should still wear that protection just incase man
Old Sep 22, 2006 | 08:23 PM
Most definitely. It could still somehow deploy and it would be most uncomfortable. Becareful not to lose the cog or spring if you plan to reinstall the wheel or both wheel and airbag. Without the cog, (which lies under the airbag) your steering wheel will have vertical play in it. In otherwords, you'll be able to wiggle the wheel around even without using the tilt handle. You can't "adjust" the wheel w/o the tilt handle, just wiggle it. This makes for play in the steering column and makes it difficult to align the front it- you may get it aligned, but it will come out of alignment easy. If you have play in your wheel already, that means the cog is already broken and you should replace it while you're in there anyway.
Old Sep 23, 2006 | 04:26 PM
Mr. Wolf's Avatar
another questoin are you jsut gonna trash the old steering wheel or are you gonna put it back on?
Old Sep 23, 2006 | 04:34 PM
oneslowz28's Avatar
Just remove the screws from behind the wheel. remove the air bag witht he batt disconnected and the fuse pulled. once the air bag is out then its childs play from there
Old Sep 28, 2006 | 02:08 PM
birdman1's Avatar
why, do you want to buy one? I'm going to pull mine off next week, and put a grant wheel on it.
Old Sep 28, 2006 | 02:11 PM
Mr. Wolf's Avatar
no just to make it easier for you and plus you could deploy the bag just to watch it. if you were gonna trash it
Old Sep 28, 2006 | 07:36 PM
Don't deploy the bag in the car. It smells awful and the dust is hard to get rid of...totally not worth the 2.4 seconds of excitement.
Old Sep 29, 2006 | 08:52 AM
Mr. Wolf's Avatar
Aww your no fun
Old Sep 29, 2006 | 06:01 PM
resurrectedz28's Avatar
I always did the battery, fuse, as well as unplugging the connector underneath the steering wheel for the drivers side (one on the passenger side too but i couldn't get to it). Dunno if it mattered or not but theyve got a reserve power module if the battery dosen't work so I didn't want to take chances.
Old Sep 30, 2006 | 10:08 AM
Its also recommended that you wait at least 20 minutes after pulling the fuse/disconnecting the battery. The DERM module stores power so that the airbag can be deployed if the electrical system is damaged. It takes a few minutes for the storage capacitor to bleed down.
Old Mar 10, 2010 | 11:09 AM
Red96Lt1's Avatar
Give me some more info on the cog. Got a pic or p/n? My wheel has had play in it ever since I got it. I would love to get rid of it.
