help me fix me headliner
Old Mar 20, 2006 | 12:04 AM
kirschman's Avatar
My engine let go bout 3 yrs. ago,divorce so funds where low and I had to let the car sit in the garage. I'm real close to getting it running again and I just noticed the other night that my headliner had fallen in the two (hardtop) recessed areas of the liner. Its still holding in the center and the front and back. Can I just pull the molding from the sides and maybe spray some adheisive and straigten it back out maybe? Or do I have to replace the whole damn thing. Guess I should have cracked the windows alittle eh??
Old Mar 22, 2006 | 03:11 PM
kirschman's Avatar
Re: help me fix me headliner
bump, bump
Old Mar 22, 2006 | 04:26 PM
RedHottG2's Avatar
I rigged mine, all I did was use bobby pins (I think that's what there called) and stuck them through the head liner in place you couldn't see them. There really small and placed in the right spots will do the trick if you don't feel like replacing the head liner or maybe just for a temporary fix. No one has ever even noticed that's what I did for mine. Just an idea.
Old Mar 23, 2006 | 01:17 AM
Koby's Avatar
Well....look at this way....it is already bad, why not try to use some adhesive spray and see if it works, if not, then you aren't out much and you have to buy a new one......if it does work then you just saved yourself around hundred bucks.
magman
Apr 15, 2016 03:08 AM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
scottcba1
Sep 8, 2015 09:52 AM
