Hella Fog lamps
Old Mar 22, 2008 | 09:37 PM
neil350's Avatar
Hella Fog lamps
Picked up a set of Optilux 4 inch Fog lamps, been looking online, haven't found much. But just making sure, the red wire is hot and the green is ground correct? I only have two wires, no led ring. So I imagine red would mean power, unless it was the color blind guys day to wire at hella. When I looked on line, I saw the green being used also as a power wire, which wouldnt make sense to have a red ground
Old Mar 22, 2008 | 11:36 PM
lt1 beast's Avatar
usually the fog lights will ground to the body any all you need is a power wire. I would think that green would be ground and red is hott.
Old Mar 23, 2008 | 03:17 PM
neil350's Avatar
I want to retain my factory on/off switch, so I plan work these in to the factory fog lamp harness.
HibachiZ28
Nov 6, 2015 12:53 AM
IndyZman
Oct 22, 2015 02:17 PM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
marlar98
Sep 19, 2015 07:53 AM
Aug 17, 2015 09:50 AM
