hella FF75 conversion question!!
Old May 31, 2003 | 11:01 PM
whiteheartbeat's Avatar
Does anyone that has done this know when i upgrade to 100W bulbs,if i can use the wiring that comes with the Hella's or do i need thicker wires then that???? I am using the relays with 30Amp fuse.Also,what bulbs would be the most recommended ones,and where could i get them???? thanks
my sig
Centerline 18x8,18x9.5 wheels,255/35/18,285/35/18 Dunlop tires, Arizona Speed & Marine cold air,mass air sensor,March pulleys,Borla cat back,Hypertech programmer,Mac springs,KYB adjustable shocks,BMR stb,clear corners,clear headlight covers,MAF sensor,BBK throttle body,harwood ram air hood/carbon fiber insert,carbon fiber 69 style Z28 badges,shaved rear panel,no cats,hella FF75 headlight conversion,mesh grille insert,hockey stick stripes,
Old Jun 2, 2003 | 09:58 AM
pu12en12g's Avatar
If you are doing it purely as a upgrade for safer lighting, then I suggest 100w Clear bulbs.
If you want the HID look, I suggest Krypton, Nokya, Showoff or FX.
I am running FX 5000k 100w bulbs right now. Not the 100w LOOK bulbs... but true 100W.
Plan on getting a headlight harness upgrade, they are well worth it.
Old Jun 2, 2003 | 04:52 PM
thanks for the info!!! Also,where would i get a headlight harness upgrade,and what does it involve? I mean is it real hard to do it??
If you could let me know that would be awsome!!! Thanks
my sig
Old Jun 2, 2003 | 10:18 PM
pu12en12g's Avatar
Here ya go !
http://suvlights.tripod.com/suvlight...re-harness.htm
Old Jun 4, 2003 | 07:13 AM
94BlackBowtie's Avatar
I would say that if you are even going to fool with the wiring to any extent, just do a completely new harness - which basically means, you are going to have to make your own - just use 12 gauge wire or sumpin. The SUV lights harness that pure linked to would be excellent, but just from looking, I doubt it will fit our cars, would be ling enough I am guessing - so you could just get it, and probably extend it (it may work, but I am guessing that if it is for SUV upgrades...SUV's don't have a 10' nose like we do...
I would just put a relay and fuse in the stock harness (supplied with the Hella's), get some 100 watt bulbs, and call it a day.
Old Jun 4, 2003 | 09:32 AM
pu12en12g's Avatar
Bowtie,
Why does the wiring need to be so long ? It's not a long distance from the battery to the headlights...
I agree that the key is to use 12 gauge wiring all the way to the bulbs. Solder all connections, and 100w bulbs.
Old Jun 4, 2003 | 12:44 PM
Urgh...You know, I suppose since there is no real current flow from the switch to the relay - there is no since in having heavy gauge where from the switch to the front of the car.
Nevermind that whole little part about that - I was having a blonde monent.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 29, 2014 04:54 PM
