Hella FF75 compatibility
Old Sep 25, 2004 | 06:33 PM
gnxman87's Avatar
Do these fog lights install cleanly into 4th gen z28's? Will the factory switch still work and will the brackets install easily? Thanks.
Old Sep 25, 2004 | 06:54 PM
ianwells100's Avatar
Re: Hella FF75 compatibility
yes and yes, look at my sig, i got them, and love them... i did all the wiring myself, cuz i didnt have fogs before
Old Sep 28, 2004 | 07:42 AM
95_LT1_6SPD's Avatar
i just insatlled 4 ff75's for my headlights and am loving them. They are a breeze to wire also, just splice the stock positive negative and be done. And they are bright.
Old Sep 28, 2004 | 09:36 PM
Bud M's Avatar
http://pg.photos.yahoo.com/ph/buds93...&.dnm=00ae.jpg
I made mounting brackets from aluminum and tapped into the existing wiring.
Old Oct 12, 2004 | 02:20 AM
NJLT1SS's Avatar
I just recieved my FF75's today, and I cant wait to replace those worthless factory fogs. So I can run these off the factory wiring to the fogs and not use the wiring kit supplied by Hella? This would save a lot of time, along with being able to use the factory switch and have them come on with my headlights. Thanks for any tech tips on installing these.
Nick
Old Oct 12, 2004 | 02:16 PM
Z28SORR's Avatar
Check the wire gage size in the Hella kit against the factory. If the factory wire is the same or larger you wouldn't have any trouble. If it's smaller than your going to have to check amp ratings on the lights or use the Hella kit.
Old Oct 12, 2004 | 03:55 PM
94BlackBowtie's Avatar
http://www.lightguide.cz28.com/custom.html
HibachiZ28
Nov 6, 2015 12:53 AM
Red1
Feb 1, 2003 02:14 PM
Josh Z95
Jan 19, 2003 11:26 PM
silver97Z
Dec 30, 2002 07:16 PM
