headlights
Hey guys, 2001 Z28 here. The head light lens are gross and we tried to clean em up with Meguiar's PlastX but it didn't seem to have the same results I wanted.
I noticed theres a little silver clip on the lens. Does the lens come off the the headlight assembly? I'd really like to be able to clean the lens from behind. Thanks a lot fellas! |
To get the results you're looking for will require sanding the outter lens with a very fine sand paper, or buying new lenses.
Originally Posted by Kris93/95Z28
(Post 5083610)
Originally Posted by OUMike
(Post 5083678)
So when you say replacing the lens, your inferring that they come off without replacing the entire headlight assembly?
Yes I meant headlight assembly. Sorry for the confusion. |
Before ditching the headlights, you might want to try Mothers Mag Aluminum polish and a power ball. I've seen this clean up headlights before with good results.
