polished headlights?
Old Apr 12, 2006 | 06:20 PM
camaro_five0's Avatar
my headlights are starting to haze over. anyone know the best kind of polish or treatment for it?
Old Apr 12, 2006 | 06:23 PM
lethal93ta's Avatar
Re: polished headlights?
permatex is making a kit now that works great.
Old Apr 12, 2006 | 08:37 PM
RacingTiger04's Avatar
if its just a haze on the outside take some mothers metal polish to em and itll be gone. that works appearance wise anyway, not sure if it cures the light cutting or not, but it does clear the appearance of the lens up a LOT
Old Apr 13, 2006 | 10:42 PM
Brangeta's Avatar
Do you mean that your headlights are getting condensation/yellowing on the inside? If so, I believe you have to take the headlights apart somehow and clean it out.
Old Apr 14, 2006 | 06:53 AM
teke184's Avatar
bottom of the page...gives you some tips that worked for me.
the reason i went with the polishes is because my local parts store didn't stock anything finer than the 1000 grit wet/dry paper...they now carry 1500 and 2000
which would be a good idea to use.
pretty simple
Old Apr 14, 2006 | 10:48 AM
TruDualed95Z's Avatar
pretty simple
is each headlight pretty easy to open up in order to clean?
Old Apr 14, 2006 | 12:30 PM
teke184's Avatar
who said you had to open it up....the "haze" is external and from road debris and weather exposure.
at least all the hazy headlights i've seen on LS1s...
i did all the polishing with the lights still on the car...just be carefull around the edge.
i've gone through and pulled the lights apart to paint the inside...and there was no visible difference or haziness on the inside...it was ALL external.
Old Apr 16, 2006 | 03:58 PM
wow i assumed it was all internal. that works.
Old Apr 19, 2006 | 11:09 AM
teke184's Avatar
another misconception twarted....
enjoy
Old Apr 19, 2006 | 10:53 PM
so i took to each hadlight with steel wool and many, many different plastic polishes and they cleaned up a little but nothing miraculous. i think a set of halo's are in my near future...
football4life
Oct 4, 2015 07:48 AM
Greg88
Sep 20, 2015 07:14 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
