headlight spring.
Old Aug 12, 2010 | 11:06 PM
rpinson's Avatar
headlight spring.
I've replaced both my headlights in the last couple of months and both times the spring that holds it in place has been so stretched out that it is pointless to even try to re-use it. Right now my drivers side headlight points about 3 feet too high because of this. Anybody else ran into this problem and whats the best fix? I haven't been able to find a part # either. It's getting extremely annoying. There is essentially nothing holding the lights in place.
Old Aug 13, 2010 | 05:26 PM
Brangeta's Avatar
For '93-'97 Camaro, correct? The two springs on each side?
There's several hex or whatever screws that control the angle of the lights. Have you tried adjusting those?
Old Aug 13, 2010 | 05:49 PM
Brangeta's Avatar
Don't know if this is what you'll need, but found these while randomly browsing ebay for cheap Camaro parts.
http://cgi.ebay.com/ebaymotors/93-94...Q5fAccessories
Old Aug 14, 2010 | 12:31 AM
rpinson's Avatar
It was a single spring in the middle of the light that attached to the bottom and the other end attached to the backing plate behind the light. The spring was so stretched that it was impossible to reuse and that was what essentially held the headlight in place. I'll try to take a picture tomorrow, but it might be tough to show since the spring is no longer there.
Old Aug 14, 2010 | 12:33 AM
rpinson's Avatar
No, this spring attached to the housing itself. I probably should have opened the housing and replaced the light instead of removing it all, but I didn't and that's where the problem lies.
Old Aug 16, 2010 | 10:53 AM
Z28SORR's Avatar
You should be able to get this spring from a Junk Yard, may have to take the whole light bucket. The Dealer should also have them, but will often tell you they don't, because they just don't want to bother. Auto Parts may have them in the "Help" section or you may be able to match it from the universal spring box.
The most likely reason it's stretched out is because you cranked the vertical light adjuster screw all the way in.
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
