Door guard bumper strips...
Old Aug 13, 2010 | 08:13 PM
LSWHO's Avatar
I've tried searching all over. No info to be found I guess.
If I take these off is the door painted underneath?
And what's the easiest way to remove them? Blowdryer?
I assume the paint will probably by now be new looking if it is still there and therefor will probably look pretty bad in itself?
They are so ugly faded now They need to be removed.
Old Aug 15, 2010 | 07:33 AM
Chevyssoccer's Avatar
Yes, the door is painted underneath.
Heat will make it easier, just leave the car in the sun for awhile. I used a plastic panel tool that looks like a tire spoon. Its not hard to get the trim off, its far more time consuming to remove the glue and dirt residue. As far as fade, if it is noticeable you could just paint the trim and put it back on.
Old Aug 15, 2010 | 12:48 PM
slayer6x6's Avatar
I've also heard of guys using fishing line to get behind the strips to help separate from the body.
Old Aug 17, 2010 | 02:10 PM
Procharged94Lt1's Avatar
You can also just use a hair dryer to warm up the pieces as well- a heat gun will work as well but if you aren't careful can warp the trim pieces if you were trying to save them. If you don't have fishing line could always just grab some dental floss.
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
alliance12364
Sep 23, 2015 12:40 PM
z28cam1993
Sep 9, 2015 04:08 AM
92_RS_305
Sep 8, 2015 07:47 PM
