Head Lights
Old Jun 8, 2003 | 05:25 PM
shootcallerz28's Avatar
Head Lights
Where can i find the head lights for a 93-97 z28 that you can change the bulbs in them want to run brighter bulb thanks
Old Jun 8, 2003 | 07:32 PM
Brent94Z's Avatar
Super Moderator
I'll COPY this over to the Appearance Section. It seems many of our resident lighting experts hang out over there more than here
Old Jun 8, 2003 | 07:35 PM
silver97Z's Avatar
If you want to run brighter bulbs you have 2 choices...either pull the bulbs out of the stock headlights, install new ones, and run the risk of breaking the headlight OR buy new headlight assemblies (hella 90mm or hella ff75 seem to be the most popular right now).
Old Jun 8, 2003 | 08:31 PM
AW/whiteZ-28's Avatar
Or you can get autooptiks replacement headlights that let you change the bulb (looks stock)
www.autooptiks.com
Old Jun 9, 2003 | 01:49 AM
Taker's Avatar
why do the stock headlights break with new bulbs? i was thinking about getting some of those bright ion blue bulbs and replacing my stock bulbs..buddy of mine has done them on his new camaro and they look great and his lights dont break? or is this just a pontiac headlight problem?
Old Jun 9, 2003 | 08:07 AM
94BlackBowtie's Avatar
Originally posted by Taker
why do the stock headlights break with new bulbs? ...or is this just a pontiac headlight problem?
He just said you run the risk - the stock headlights on 93-97 Camaro's are known to crack every so, and the housings have crappy reflecting qualities anyhow. I would think that Pontiac's would be in a totally different ballgame, since they have a totally different setup.
Please don't do that - they are worse BYFAR than the stock housings. That does sound like what you are looking for in your post - but I would strongly not suggest it.
If you want to keep your stock housings, and keep everything the way it is without spending much - just check this website out.
Old Jun 9, 2003 | 12:25 PM
Sam95ZNoTop's Avatar
Originally posted by 94BlackBowtie
Autooptiks
I agree. Just a waste of $$. I was also a know-better and bought autooptiks housings... Needless to say, they are collecting dust in my garage right now. They are truly WORSE than the stock lights. I would HIGHLY recommend changing housings as they are the problem, there's nothing wrong with the bulbs, the reflector in the stock housing is just a POS!
If you are willing to change from the stock look, check out the Hella 90mm conversion I have done (link in sig)
HTH
Sam
Old Jun 9, 2003 | 05:41 PM
Bom2000's Avatar
How much are the hella 90 mm and where can I get them... I figure that you would get them off like but would a local auto store like pep boys or auto zone have them???? And are they that hard to install? Thank you in advance
Old Jun 9, 2003 | 08:05 PM
StreamlineZ28's Avatar
that sounds pretty easy i think i will try that, i new i kept my old burnt out lights for a reason.
Old Jun 9, 2003 | 11:01 PM
Check link in my sig, all the info is there.
Sam
Jlo
Feb 3, 2015 09:41 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
isimplyexist
Mar 25, 2004 08:06 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
