has anyone removed stock GFX front, 99Z28?
Old Jul 14, 2003 | 08:08 PM
camaro322hp's Avatar
anyone pulled these off? i'm looking to remove the 2 pieces on the FRONT ONLY. any tips would be appreciated.
thanks
edit: not "stock". i know they're optional. i meant the GFX that come from the factory with the sport appearance package...
Old Jul 14, 2003 | 10:58 PM
mr_muff's Avatar
the liscesnse plate bracket?
Old Jul 14, 2003 | 11:18 PM
no. the ground effects. you've seen them, you know, those two peices on either side of the front fascia on the bottom. only on cars with the sport appearance package.
check my site, linked at bottom, you'll see what i mean.
Old Jul 14, 2003 | 11:32 PM
XTZ's Avatar
XTZ
While you're at it remove the rest of the sport appearance package and you'll have a regular Z
Old Jul 14, 2003 | 11:40 PM
mr_muff's Avatar
ah, body kits. your on your own on that one.
Old Jul 15, 2003 | 02:50 AM
99huggerorangeZ's Avatar
Question
Old Jul 15, 2003 | 07:25 AM
My84Z's Avatar
I have seen poeple knock theres off with parking curbs then just leave them off. all you do is heat it up with a blow dryer so the glue becomes less sticky and pull then just use goo gone or something like that to take off the left over glue and they are gone also if you want to get rid of them let me know.
Old Jul 15, 2003 | 07:38 AM
Bone Maro's Avatar
They're held on with 3M red double-sided tape. Good stuff, ansd holds pieces on well over 150+ mph
Anyways. Heat the bonding area up with a heat gun or blow dryer, and gently rock the piece back and forth, this will loosen up the adhesive. After awhile, pull the piece off.
Use 3M adhesive remover to get all leftovers off, then wax the area and it'll look like the GFX were never there
DirtyDaveW
Dec 1, 2016 05:37 PM
rjc1629
Jan 27, 2015 10:46 AM
siguy
Nov 27, 2014 10:07 AM
