GREAT upgrade for those crappy headlights!! (photos w/ in)
Old Jan 7, 2007 | 09:21 PM
  #316
guywithaZ's Avatar
Originally Posted by Z95m6
I personally think the 50mm's would look terrible because they're way to small. The 90mm's are just right as far as lens size goes. I just wish they weren't so damn deep.
Could they be used as fog lights...or are they too big to fit.
Old Jan 7, 2007 | 10:03 PM
  #317
Z95m6's Avatar
www.rallylights.com has the dimensions of all the lights.
Old Jan 8, 2007 | 08:50 PM
  #318
guywithaZ's Avatar
So to get the 90mm to be HID do I have to buy the whole hella HID kit (like a thousand bucks for 2 ), or can another HID conversion be bought and placed inside the housing . I thought I read something had to be trimmed to make this method work, or am I way off. Thanks.
Old Jan 17, 2007 | 01:40 PM
  #319
Sam95ZNoTop's Avatar
Just to answer a few questions that have come up:
The european beam pattern (ECE)is like this:
....../ i.e. it keeps going up at a constant angle on the right
___/
The US pattern (DOT) is:
......______ i.e. it gets cut off at a certain height on the right.
___/
The corner where the lower part of the beam meets the angled part needs to be aimed straight ahead.
The idea of the higher cutoff on the right is to light up the side of the road and the signs that are there.
The beam pattern is much wider than the stock lighting, so you'll notice that you won't need any foglights to "light up the sides of the road" anymore.
If you want to have HID, you can go the hard route (as I did ) or the easy route which is to buy the D2S housing for $150 a piece at rallylights and then buy a set of D2S bulbs and ballasts on eBay. I got them there for ~$200. I modified my regular 90mm modules and that took me a lot of work and testing...
HTH and thanks for keeping the thread alive!
Sam
Old Jan 17, 2007 | 02:07 PM
  #320
Z95m6's Avatar
___/
___/
Sam
Here is a guide showing how to convert the 90mm's to HIDs.
http://www.msprotege.com/forum/showt...&highlight=HID
I installed some hyper white 100watt bulbs in my 90mm's and then put a pair of my old FF75 Driving lights in place of my Fogs. The Driving lights really make a big difference with the 90mm's, the Fogs were tough to tell they were on with the 90's on.
Old Jan 18, 2007 | 07:04 PM
  #321
camarolt4ss's Avatar
830 bucks? holy ****....
Old Jul 25, 2007 | 10:04 PM
  #322
I also saw that write-up. However, look at the beam pattern on the wall! That's not how it is supposed to look! Somehow the position of the bulb is not right. As I said earlier, that is the hardest part about the conversion to HID and it takes a lot of trial and error to get it right with the hardware that you have as a DIY'er.
Thansk for keeping this alive! I still get emailed questions about this conversion on a regular basis. Even years later!
Sam
Old May 4, 2008 | 01:50 AM
  #323
96SilverRam's Avatar
That looks very nice
Old May 4, 2008 | 10:40 AM
  #324
pu12en12g's Avatar
Thanks man... still adjusting the cutoff but here's another shot:
Old May 4, 2008 | 09:18 PM
  #325
That looks good! Turns out that you ended up going the Hella 90mm way after all! I see that you are using threaded rod... When I did my upgrade to HID, I actually used some log 1/4-20 screws with washers and nuts on the car mounting holes. It's much more solid than the Hella adjusters and easier to adjust!
I like the idea of spraying everything a matte black, kinda prevents you from seeing too much of the stuff back there. Thaks for the idea!
Sam
Old May 4, 2008 | 10:01 PM
  #326
Violat0rX's Avatar
looks good!
Old May 8, 2009 | 01:27 PM
  #327
c110's Avatar
I hand bent a couple metal brackets and mounted them about 3/4" behind the stock assembly. I had to hammer the core support a bit for the low beam. Someday I might add a trim panel.
Old May 9, 2009 | 10:17 AM
  #328
Bud M's Avatar
The FF75s are what you want to use for fogs, they fit perfectly. I've installed them in 2 Camaros.
Old May 9, 2009 | 10:20 AM
  #329
Bud M's Avatar
Nice work!
Old May 11, 2009 | 09:59 PM
  #330
Originally Posted by Bud M
Nice work!
Very nice work! Doesn't look hand bent at all!
