Got hazy '98+ Headlights? Solution inside!
Old Sep 29, 2003 | 08:50 AM
94BlackBowtie's Avatar
Lightbulb Got hazy '98+ Headlights? Solution inside!
First off - thanks to joshp14 and his thread about cleaning up tail lights.
This same process should most definitely work on the headlights, and is also very cost effective. Just to provide with a little more info than what I am quoting below, he used this compound from Eastwood Co. Also, if you need the buffing wheel, and can't find one close to you, you can get them from Eastwood as well.
Now - this is from the other thread.
Originally posted by joshp14
Nothing a little plastic polishing compound can't handle! What do you all think?
First pic is my 88 TA and second pic is the third brake light on my 95.
__________________________________________________ __
Hey guys. Glad you like it. Yes, that haziness is the "before" and the "shinyness" is the after. All you need is a die grinder (I used pneumatic), a loose-style buffing wheel (a little 3" will work), and plastic polishing compound from www.eastwood.com ...If you head over to that site, it's the blue compound, and it runs about $5 for a bar of it.
Just apply that compound to your buffing wheel and buff away. Be sure to NOT stop on one part of the light. Be sure to keep moving as you don't want heat build-up and discoloring your tail lights or leaving burn marks. I did this on my 95 tail lights as well but I don't have pics up yet.
Happy buffing!
There is no reason why this wouldn't do the same for the '98+ headlights, as they are the same stuff as the other. So, this looks like a great solution to this problem!
Old Sep 29, 2003 | 10:52 AM
teke184's Avatar
finally!!!!
thank the lord...i've been trying numerous things and nothing has worked!!
guess i'll be doing the headlight paint mod and the polish mod here pretty quick!!
thanks man!!
Old Oct 2, 2003 | 01:30 PM
I found this at Eastwood as well - they both should work equally as good.
Old Oct 4, 2003 | 04:09 PM
GoFast908Z's Avatar
Member
what kind of polishing wheel do you need?? How much do they cost and where can you get them. Can you use a dremel tool?
Old Oct 4, 2003 | 04:12 PM
RENE95Z's Avatar
You can get buffing wheels at Home Depot, Lowe's, etc. They come anywhere from a 2" wheel to a 4" from what I've seen. They should come with an attachment so you can use it in your drill.
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
z28newbie
Sep 9, 2015 10:26 AM
