Glue for stainless badges?
Old May 2, 2007 | 03:35 PM
Vamp's Avatar
I found some nice looking stainless CAMARO inserts that have there own glue backing, but I also have the same Z28 badges but they have none. I was wondering what kind of glue would work best to stick those badges on without damaging the paint if I needed to take them off someday.
Also, any tricks any of you used to remove vinyls? The CAMARO inserts look a bit tricky.
Old May 2, 2007 | 04:02 PM
gt_biker13's Avatar
Use double sided tape to put the emblems on. To get vynel or double sided tape off you need to use WD-40 or Goo-gone. Just let it soak then use your finger nails to start to peel it off. I think it works better if its warm so try a hair dryer or heat gun. Be careful if your using a heat gone though, it can make it too hot.
Old May 2, 2007 | 04:31 PM
Vamp's Avatar
Thanks for the great advise, I'll give that goo-gone a shot.
Old May 2, 2007 | 10:55 PM
eric99's Avatar
where did you find the stainless z28 emblems ?
Kinglouui
May 26, 2016 11:05 AM
Quickss96
Jan 29, 2016 05:56 PM
n2oblkz
Oct 12, 2015 01:53 AM
mlopezart
Sep 8, 2015 12:15 PM
alphaauto
Jul 26, 2015 04:40 PM
