fog lights, wiring going through firewall
Old Sep 15, 2003 | 08:13 AM
NewbieWar's Avatar
where is the best place to get the wiring back under the hood?
got my lights installed, and got my switch mounted... now just gotta connect the wires.
Old Sep 15, 2003 | 03:24 PM
nothingeined's Avatar
Yup, through the firewall. Just look past your passenger side kick panel and you can get em through there. You could also go through the side of door if you are too lazy like I did my on 93. It looks kinda tacky though
Old Sep 15, 2003 | 03:39 PM
SloTexanTA's Avatar
You can also try on the driver's side, where the hood latch cable runs through the firewall. Just pull back the grommet a little bit and slide the wire through. It's high enough on the firewall you don't really have to worry about water or anything, plus it gets you in right where you want, on the driver's side. The down side is if you have the relay from the lights next to the battery, you have to run the wire through the engine compartment to the hole, and that looks tacky. But if you don't care, take your pick.
Old Sep 15, 2003 | 09:08 PM
NAVY01Z's Avatar
If your car is a 98 and up you can easily get it through behind the computer in the top passenger side of the engine compartment. Just take off the cover and take out the two bolts holding the computer down. You can then move the computer enough to get to the grommet behind it and run the wire through. I was able to get two 4ga power wires for my stereo through that grommet so there should be plenty of room.
Old Sep 15, 2003 | 09:20 PM
notstock4long's Avatar
Actually, it is the same on 93-97s also. I have the same hole in the same spot on my car.
Old Sep 15, 2003 | 09:42 PM
NAVY01Z's Avatar
Well then I guess it doesn't matter which year.
I really think that would be the best way to go.
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
30thZ286speed
Aug 3, 2002 04:54 AM
