Flexible primer needed for painting gfx?
Old Jan 14, 2006 | 02:22 PM
SplitFire's Avatar
Tomorrow I plan on painting my gfx. When I asked the local paint shop what primer I should use on them, he just gave me a can of bulldog adhesion promoter. On the can it says that it is used to make paint stick to gfx but from what I have read online, most people will still use a primer after this.
The only other kind of primer I have is a duplicolor sandable primer. Would this be ok to use or would it need to be flexible?
Old Jan 15, 2006 | 11:12 PM
lsercastikl's Avatar
Re: Flexible primer needed for painting gfx?
scuff it with 400, bulldog it, use real primer like urethane primer,scuff it with 400 grit, than id bulldog it again and paint while the bulldog is tacky.
J
Old Jan 17, 2006 | 11:26 PM
FireChicken1995's Avatar
just use normal primer dont waste your time or money on other stuff iv done ground effects and NEVER have a problem with them cracking paint will flex ALOT more than people think it will the knowlege i know comes from my ole man who builds custom cars for a living and a few have gone on barret jackson just dont want you to think im some red neck with rattle can good luck painting
Old Jan 18, 2006 | 08:05 AM
Fast Orange's Avatar
id agree.. normal paint will work.. most flex additives are only there to allow the paint to stay soft enough to install the part.. then it evaporates.. as far as flexible primer.. no matter how far the primer will flex, the paint will only flex so much.. i would just use the real urathane primer.. if it is raw rubber or smc.. you can use bumper cladding then paint.. if its already black and kinda rough then use some red scotch bright and 400.. then use sealer and paint.. youll be all good..
Old Jan 18, 2006 | 11:22 AM
CamaroCasanova's Avatar
Don't listen to them, use the bulldog-you should use regular polyprimer and then ADD bulldog in liquid form to your primer (as in not the canned kind), you can also use it in the paint-it helps adhesion and it helps give it flex properties, and trust me, you want those on gfx.
Old Jan 18, 2006 | 03:54 PM
SplitFire's Avatar
Thanks for the replies. I ended up buying a flexible urethane primer a couple days ago. Unfortunately he gave me white primer and I'm using black paint. I don't know if it'd take a lot more paint to cover up the white primer, but I think i'll return it and get something a little darker.
Old Jan 18, 2006 | 04:05 PM
Red face Re: Flexible primer needed for painting gfx?
all i can do is shake my head.. whatever though.. your probably a professional or somebody important.. rotflmao
Old Jan 18, 2006 | 07:50 PM
From my experience bulldog can be used in the actual basecoat as well as the primer and it works quite well.
But what do I know?
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Lederman1976
Nov 30, 2014 05:21 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
